My new rims!!
alx954
My new rims!!
Post by alx954 »
Hey guys check it out just got em today.
15x8 and 15x9 :D
But what kind of lug nuts can I use???
undesiredshoe
Post by undesiredshoe »
i think those wheels were 4x100 and someone drilled out the holes to be wider.
ImageStock block ka24e - 12.81 @ 113mph
xtearsfallforeverx
Post by xtearsfallforeverx »
ew for steelies... even with a lip.
Image 1990 s13 hatch DD I/H/E Fidanza flywheel, MSD coil, walbro 255
Image 1990 s13 hatch / fully built kade swap *soon to be force fed via t3/60-1 .63ar
alx954
Post by alx954 »
No way they look hot on the car man, youll see. + their aluminies :lol:
sticky
Post by sticky »
Well you can clearly see the bolt holes have been drilled out. But other than that, they dont look bad...........
alx954
Post by alx954 »
you guys think this will be safe
Miami240
Post by Miami240 »
They look like they require a short shank lug nut.
12508 SW 117 Ct.
Miami, FL 33186
Ph: (305) 251-1995
alx954
Post by alx954 »
like the one in the picture right???
Miami240
Post by Miami240 »
Yes, but shorter. Those pictured have a 1.38" shank length. There are some that look just like it but with a .75" or .55" shank length also. You need to measure the thickness of the center... from outside face where lugnut sits to the back side where the rim presses against the hub.
12508 SW 117 Ct.
Miami, FL 33186
Ph: (305) 251-1995
undesiredshoe
i dont know about using those rims though. The fact that the holes are drilled out means that the lug nut wont be pressing down on the whole face...only about 50%. That and the hub isnt the right size.
Edit: If you really dont want to get new wheels...i would get new, conical seat holes drilled into the extra space
alx954
Post by alx954 »
Thanks for the help guys, I went the safe route and ordered some longer
studs.
virgindrifter
Post by virgindrifter »
jsut get longer studs!!
keaser06
Post by keaser06 »
whats the offset on those?? im looking at getting some 15x8s that have a 0 offset but i dont want to have to roll my fenders or put over fenders on
"Horsepower sells cars, Torque wins races"
-Carrol Shelby
"Turbo lag is gods way of giving v8's a chance."
alx954
Post by alx954 »
Got them mounted, now I just need to lower it a bit more.
sonicnofadz
Post by sonicnofadz »
Damn that **** looks ghetto as hell.
boyce
Post by boyce »
Miami240 wrote:Yes, but shorter. Those pictured have a 1.38" shank length. There are some that look just like it but with a .75" or .55" shank length also. You need to measure the thickness of the center... from outside face where lugnut sits to the back side where the rim presses against the hub.
My old 77 corvette had ghetto ass rims on it with drilled holes.... even with shank lugs and washers the back rims would get lose every 300 miles or so and need tighten, then I got new rims.
Ditch those ugly things.
twofortydriver wrote:he got t-boned by a fire hydrant trying to drift before he could do the swap
Post by Justin L »
Ahh i hate you. I want a corolla so bad. Looks good. Lower that baby some more.
Razo240sx
Post by Razo240sx »
those rims look bad ass.
whatsrdrifter18
Post by whatsrdrifter18 »
save up and buy something better
92 ka24de-t almost done
bam 240sx
Post by bam 240sx »
haha love the first pic bro
2389cc_S14
Post by 2389cc_S14 »
Those wheels look like they're going to block air going to the brakes :?
~T3/TO4E, 50 lbs inj, Z32 MAF, Enthalpy ECU, JGS mani, 8.8:1 Arias, Apex GT Spec Exh
alx954
Post by alx954 »
Man my thread is back!!!
Also I dont think my brakes are going to get affected too badly, I have
rx7 brakes up front anyways.
Also almost done on the ka swap into this badboy :D
Spud5251
Post by Spud5251 »
what is the point of having an 9 inch wide rim if you are going to put a tire that is only 6 inches wide?
Too much to list.
KA26DE-T in the making. BC Stroker Kit, Kelford 272's, borg warner s258 (18-20 psi)9.5 to 1 compression, Full Race Twin Scroll, and a few more goodies.....
alx954
Post by alx954 »
old pics and only tires I had at the time, have bf 235's on now.
Spud5251
Post by Spud5251 »
oh, well kick ass then
ps, boo on streached tires
Too much to list.
feito
Post by feito »
Dude, do you have any more info on the fitment of these rims? Have you been running them? Any problems? I have a sweet ass set of enkei mesh that are 4x100 so I'm contemplating on redrilling them leaving them just like yours.
hnugen
Post by hnugen »
that is some ghetto ass sht. very unsafe. i wouldnt let my enemy drive on those for fear of hurting OTHER people when the wheels pop off driving down the road. Believe me when I say it's a matter of time before that thing comes loose or the studs break, sending the wheel down the road. I've dodged spinners, hubcaps, a wheel...the one time I hit something was when my friend was driving and we dodged a Tahoe wheel but got hit with the brake drum. Take those wheels off before it gets someone hurt/killed or smashes someone's car and you get sued. They look great nonetheless :D
