New SOHC setup.
Jordan Gladman
New SOHC setup.
Post by Jordan Gladman »
Setup:
-KA24E SOHC
-Eagle Rods
-CP 89mm Pistons 7.8:1 final CR
-ARP 10mm stud kit
-Cometic headgasket
-Full bearing and seal rebuild
-Colt C404 turbo cam
-280Z turbo high volume oil pump
-Powder coated pan, valve cover, pipes etc
-JDM Sport GT35
-Custom Gladman Performance equal length top mount manifold
-Emusa 38mm wastegate *dumped
-3" downpipe
-custom hot pipe/cold pipe w/Z32 blow through setup
-HKS Black BOV
-Ebay FMIC
-Seimen 60lb injectors
-Custom sheet metal intake manifold
-80mm billet throttle body
-255lph pump
-3" Megan exhaust w/ test pipe
-Custom tuned ECU
-S-AFC w/ Innovative LM-1 wideband for fine tuning.
-F1 racing stage 4 clutch kit w/ 6 puck ceramic disc
-F1 racing 11lb moly flywheel
-VLSD rear diff
-Emusa 8/6kg coil-overs (dont buy)
-5 lug conversion w/ Q45 front brake conversion
-17X 9/10.5" 03' Cobra Wheels
Couple pulls. (ignore the wideband, i had just blown the factory 02 out of the bung when I hit rev limit so I was sucking wind)
http://www.streetfire.net/video/sohc-ka24et_2056867.htm
http://www.streetfire.net/video/sohc-ka24et_2056869.htm
http://www.streetfire.net/video/sohc-ka24et_2056873.htm
Pics:
Factory S13 tape deck, better believe it!
Last edited by Jordan Gladman on Mon Sep 06, 2010 12:59 pm, edited 6 times in total.
240tuned91
Post by 240tuned91 »
hows the q brakes you running them in the back too? also what kinda paint did u use for the bay its really glossey wet looking. you sand a lot and prep it?
Post by TanManS14 »
Car looks sexy as hell. What wheels are those? Yay for low ass compression. Sh*ts prolly close to being non interference motor at that point lol. Id always rather run more boost on pump/ be more protected from detonation than spool 200rpm sooner.
turbonola
Post by turbonola »
what projectors are those?
11.65@118 1.64 60ft
Jordan Gladman
Q brakes are great, they're up front only right now but they feel powerful. I used regular black paint on the bay but I put 2 layers of JC620 urethane clear coat.
They're cobra wheels, and these are the projectors, coincidentally I make and sell the kits :lol:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ESELX%3AIT
Marcus
Wearer of Missing G-Strings!
Post by Marcus »
PIMP!
tom550
Post by tom550 »
dang that came out nice.
sorry if i missed it but what power are you going to be running?
rn240sx
Post by rn240sx »
Very clean motor... i wish my sohc was that clean... it can be, just too lazy to do so...
www.shopboldimpressions.com
06 Suzuki Boulevard S40
/\ all still current 8.30.20
Jordan Gladman
I still plan to order an O&J stage 2 cam, and I'll probably try and find some 550 injectors, but plan is to run 20psi daily, so it should be over 350whp, I dyno'd 348hp with the same turbo and almost the same setup at 16psi. This is also depending on the fact that I get my tuned ECU working.
mo_hish
Post by mo_hish »
Nice setup. That urethane clear coat came out really nice.
tom550
Post by tom550 »
man that is my dream car except for the pain color, rims and exaust.
how does the 180sx bumper fit?
other than those i wish that was mine. im hoping to do some crazy SOHC power in the future
ColumbusDrift
Post by ColumbusDrift »
What rims are those? What are the specs Front and Rear?
2009 RAV4 Sport (Family Vehicle)
2009 Civic Si Sedan (Daily)
96 S14 with T25 KA24DET (Weekend/Track)
Jordan Gladman
They're a take off the OEM cobra wheels, made by OEM Concept designs, 17X10.5 +27 rear and 17X9 +23 up front.
As for bumper its not a 180sx bumper, but fitment was perfect, best FRP bumper I've ever installed.
xpinoyxmk
Post by xpinoyxmk »
Nice car man. Love the lights and how the body flows.
Only thing i dont like is the wheels man... You got the wrong cobra wheels... Guess its a personal perference though. I have the other kind. Same size too for the 10.5
tom550
Post by tom550 »
o yea HA they look very similar just didnt notice the turn siginal lights.
Jordan Gladman
xpinoyxmk wrote:Nice car man. Love the lights and how the body flows.
This is where taste comes in... I think the other cobra wheels are hideous. Any pics of the wheels on your car?
xpinoyxmk
Post by xpinoyxmk »
Jordan Gladman wrote: This is where taste comes in... I think the other cobra wheels are hideous. Any pics of the wheels on your car?
Only the 2 in the back right now:
Jordan Gladman
Nm.. .those look really good, I thought you were talking about the bullit rims... I like the polished silver look, I was actually concidering having my tires pulled off so I could have my rims polished.
xpinoyxmk
Post by xpinoyxmk »
Wheels are $130 each for 17x10.5 +27 and only $15 to ship a set of them. These wheels wont fit up front though. Have to get the 17x9 size for up front.
Jordan Gladman
I had 10.5" wheels on the front of one of my setups, but they were -6 offset. You could run them up front, you'd just want 25mm spacers... mine came as a set w/ tires, if I had it my way, I would have run the 10.5's up front too ..
Snapped a day light picture today, last day with a red hood, should be throwing on the CF hood tommorrow. :wink:
xpinoyxmk
Post by xpinoyxmk »
Beautiful car regardless. What size tires? Look beefy as fuh.
Jordan Gladman
275 rear, 255 front both 40 series. I need to get narrower tires up front though so I can go a bit lower.
xpinoyxmk
Post by xpinoyxmk »
Oh, i jus noticed that you made those headlights, nice work. How come you didnt center the projectors though?
tom550
Post by tom550 »
you should post a write up about your headlights. i want those so bad but just dont have any idea how to approch it.
Post by TanManS14 »
Dude that's like asking a chef for his recipe.
hotbox240
Post by hotbox240 »
Nice looking setup will have to run um down at mission.
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
Jordan Gladman
xpinoyxmk wrote:Oh, i jus noticed that you made those headlights, nice work. How come you didnt center the projectors though?
I left a "blank" spot for a fog light or daytime running light. I will eventually put another light in beside the projector.
As for the headlights and my "recipe" I have no problem disclosing how they are made, anyone who appreciates how I made them would realize they're easier to just buy them from me. I 3d modeled the OEM headlight assembly, modified the geometry and had new panels, linkages and tie rods made. Fitment is perfect and installation only takes an hour or 2. The lighting improvement over stock is good, but I would say the visual improvements are more enjoyable, they make the S13 front end look newer.
Hotbox, I should be down for racing on the 9th if weather is permitting. Still have to tie down a few lose ends, but it should be ready to go.
blacks13coupe
Post by blacks13coupe »
Very nice car, the headlights deserve some props. One of the nicest socks I have seen.
Post by TanManS14 »
Lol sh*t man, not many are willing to elaborate on something they sell. I dont think i would if i was tryin to make a buck in an already tough market. But, it is much better for the community i suppose.
Random question, idk if you had the car painted, or did it yourself, or what; but do you guys replace all the window and door seals?? Did you have to go through nissan to get them or is there aftermaket makes that still fit worth a damn and dont ruin ur pants with burns.
Jordan Gladman
I would have liked to replace the seals but i just taped over them...
I didnt really elaborate to a degree that would make the lights easy to replicate, maybe if I offered up all my drawings and model files. Even if someone had all that info, they'd still have to pay more than I sell them for to get all the work done.
