367hp/390tq (Hy35 @ 16lbs)
They said they would email me the dyno sheet, but until then... heres a pic I took with my phone.
Vid: http://s286.photobucket.com/albums/ll82 ... G_2389.mp4
Hy35 @ 16lbs
DW 810s
N62 Maf
9:1 Wiseco pistons
AMS rods
Stock cams
Stage 1 port/polish head
Felpro headgasket
Full ARP hardware
RB20 flywheel
350z Stage 2 full-faced
Eprom tune
Safc2 for fine tuning (I hate admitting this, but I messed with the tune on the way to the dyno with the afc.. will eventually fine tune on eprom, but it was leaning out up top. That probably screwed with my timing a bit)
Build thread: http://ka-t.org/forums/viewtopic.php?t=47099
Very impressive for 16lbs. get your fuel pump hardwired and I bet it fixes your leaning out. I had to when I got up to these power levels. If not it's in your tune. When you get the fuel fixed do another pull at 21psi and she will make 400whp and 425 wtq all day long. The HY35 chokes out past 21psi with the small 9cm2 hotside. You won't gain much past 21psi and the turbo life goes downhill fast past that. I've seen a H22 honda make 450whp at 22psi on a HY35.
What mani are you using to clear the BMC with the HY35? 2.5" or 3"dp??
Thanks everyone.
I'm actually using a standard eBay bottom mount t2 mani that I flipped over, chopped the flange off of, welded a t3 flange on, and reinforced it to support the weight. Followed by a custom 3" DP.
They didn't hook up a wideband to my exhaust (I'm assuming it was to save time because it was a dyno day and there were a lot of cars going on and off) so I'm guessing that air/fuel is just the default. My afrs were pegged at 11.5 after the tip-in.
lol the guy eating the twinkie isn't me.. I was in the car.
I've actually been meaning to hardwire my fuel pump, even though it never occured to me that it might be the reason I was leaning out up top. I was just thinking it was the tune. And I'll definitely be turning the boost up soon to at least ~20. The goal is 400+.
- redline240sx
- chue240sx
I'm actually looking for a hy35 but can't find any. Let me know if u see any for sale or if u can tell me where u looked.
stock internals,t2 GT2871R, Unorthodox pulley set,FMIC, HKS SSQV 2, Apexi N1, z32 maf, nismo 740cc injectors,Prosport boost and oil guages, Innovate LC-1 WB02, enthalpy dual tune ecu for 91 and e85, Apexi N1 EvX suspension, cusco rear sway bar and front brace, megan tie bar, RUCAs, toe arms, traction arms, etc, works vsxx, Nismo solid red with white pearls, daily driving
- chue240sx
which sites exactly if you don't mind telling me. I'll search still but I'd like some recommended sites. Thanks.
Thanks Nate. I'll probably end up tracking it to see what kind of numbers I'd get on street tires.. but I'll probably max the clutch out first and see if I can break 400 on the dyno first.
Also, I haven't gotten around to tweaking the tune up top yet, but as soon as I'm happy with it, I'll throw the tune up.
WHOOT WHOOT! Congrats on the numbers!!!!!! Can't wait to get my He341 running!!!mo_hish wrote:Thanks Nate. I'll probably end up tracking it to see what kind of numbers I'd get on street tires.. but I'll probably max the clutch out first and see if I can break 400 on the dyno first.
T_T omg i can't wait. hmmm i'm thinking, $2.2k For a complete built bottom end. i was tryin to find that vid on youtube but i couldnt find it. by anychance, do you have a link to it?mo_hish wrote:Thanks bro. You're going to love it, but make sure you build that extra block of yours because you're definitely going to want to crank this boost up!
Reason why i asked is i saw that video before... maybe i clicked on it on your build thread or somewhere but i guess it was on photobucket =Dmo_hish wrote:What vid are you talking about? If you're talking about my dyno pull.. I have it on my photobucket account, not on youtube. Just click the link below the pic.
Please post some pics of your manifold conversion. U will be damn close to 400whp at 20psi and well over 425wtq at that number. These turbos are very comparable to GT2871's and GT3071's in power and spool up for 25% the cost, and they are rebuildable for about $100 at just about any turbo shop. It is the way to go for a good streetable powerband IMO. The HX35 on a T3 .70ar will make 100 more whp with slightly slower spool(300rpm). They are very compareable to the GT30R or S256BW.mo_hish wrote:Thanks everyone.
- chue240sx
can't wait to get my setup! Yikes! This gives me motivation!
It's great to see your Hy35 make these type of numbers. I also have the Holset He341 and I basicly did the same thing with a T2 manifold and it cost less than $100 to build. Here's a few pics of when I was fabbing my setup:
This picture was taken before I installed a slim brake booster.
1995 S14 daily built block nismotronics sr20det Ecu running my ka-t, synergy green S14 5.3l turbo 240sx 1/4 mile traps 135mph on 13psi and dr's.
Holset HE341 Install thread woohoo!!
viewtopic.php?t=48692
http://www.playloudclothing.com/
Yup, that mani looks almost identical to mine... angle, stud and all.
Btw, my car's for sale!!!
http://www.tristatetuners.com/forum/sho ... p?t=103123
damn those numbers are outstanding for 16 psi of boost makes me feel good about my HE351 i hope to make good torque along with horsepower...
- 91_ka24de
good ***** lord you see that front end just pick up?
"we never have money to do it right,but we always find money to do it twice"
"Money isn't really much of an issue. Only the time it takes to make it." -ILuvS13s
Hatchback,ISIS/HKS Hyper D-Max coilovers, Work Euroline DH fronts 18x8 Rears 18x9 205/40's,Wiseco Pistons,Eagle Rods,deatch work 740cc injectors 255lph,Aem Wideband, 58/63 turbo, megan FPR,Mishimoto rad,3" Apexi turbo back exhaust,Nology Hot Wires, NIStune
