that's right...ah ok...probably Arias .020" if you got it from AMSBRAD D wrote:im not too sure.. it was long ago. built by Ivan at AMS. i can mesure..
Import DPS KA24 SLEEVED Blocks Now Available!!
- KA-T.org Sponsor
We have been getting a ton of calls on these blocks. First let me start with saying we have been building these motors for over 15 years. Don't think that for 1 second because we use them you will make over 1000hp, there are so many other surrounding factors that come into play as well.
A Fully Assembled Race Block by our team with sleeves and Import DPS Signature parts will cost $7500. We have dual cam cores that we can use.
Import Drag Performance
2947-51 North Marshall Street
Philadelphia, PA 19133
866-703-8794
866-703-8794
[quote="driftfiend"]whats the benefits of plugging up the coolant passages??quote]
its a filled block. it just doesn't block the coolant passages.
a lot of drag racers do that. one for such a short time the motor is running you don't need coolant running through the block. two it makes it less prone to cracking and breaking under high hp and high boost. for a street car i would never do it.
but you can get away with a half fill on a street car. it helps
Re: Import DPS KA24 SLEEVED Blocks Now Available!!
is this still available
