bmitchell's build
bmitchell_ga
bmitchell's build
Post by bmitchell_ga »
So turboed my car back in late 2009. I never started a build thread and now that I'm
starting to go threw it again I decided to make a build thread.
My setup includeds:
Holset Hy-35
Jgs mani
Turbosmart WG 38mm
Dw 550's
Nistune
N62 maf
Hks bov (fake I think)
Avp mbc
Godspeed Intercooler
Full 3" Hks exhaust and handmade 3" dp
Act 6-puck and heavy duty pp
Fidanza Flywheel
K-sport coilovers
I have my dyno thread linked in my sig for thoughs wondering what kinda of power I'm making.
Now for this 1st pic don't be hatin on these Honda offsets. I hate my wheels and have never liked them. They where on the car when I bought It and I plan to change them out as soon as the xxr 527's come out. I spent the money on the turbo stuff instead of buying wheels.
97 S14
? @ 18psi (corn)
my build thread
bmitchell_ga
So this is what I spent the weekend doing.
97 S14
? @ 18psi (corn)
my build thread
bmitchell_ga
I pulled the motor so I could fix all my oil leaks, install a new oil pump, and timing kit, My car leaks oil so bad for example.
My parking spot. Don't step there after it rains lol.
97 S14
? @ 18psi (corn)
my build thread
bmitchell_ga
While I got the motor I am tempted to go ahead and build it. But that would chew into my badly needed wheels fund.
Also my plans this spring inclued installing an alum ds, radiator upgrade along with fans, ebc (already have a profec b in route), and maybe and injector upgrade. O and dont forget the new wheels.
I really want to just clean up under the hood and make the car more reliable. I don't daily the car but I always would like for it to be depenable for dailying.
97 S14
? @ 18psi (corn)
my build thread
DrEaMeR_VaNg
Post by DrEaMeR_VaNg »
Where was your oil leaking from? Oil pan? Front/rear seal?
Looking good though!
Kouki.Love.
bmitchell_ga
DrEaMeR_VaNg wrote:Where was your oil leaking from? Oil pan? Front/rear seal?
Around my bung on the oil pan. I guess I got a pin hole in the weld. Also my front main seal is leaking and I think my timing cover is leaking too. I have dropped the pan In the chassis before and I'm not going threw that again so I just pulled it.
97 S14
? @ 18psi (corn)
my build thread
bmitchell_ga
For the guy who requested pics of the intercooler piping.
Basically I made the hot side and used the what came with the godspeed kit for the cold side.
97 S14
? @ 18psi (corn)
my build thread
DrEaMeR_VaNg
I've dropped and install the pan under the chassis before too and it is a PITA that's why I'm gonna pull the whole damn motor out when I turbo my car next month. LOL.
That sounds like you already know what to replace, hope all goes well. :)
Kouki.Love.
bmitchell_ga
Alos does anybody know what this is? I was looking at my old short ram intake and noticed it was still in there.
I just plugged it back into my harness. It didn't change anything though. I think it's the
IAT sensor. Should I have this hooked up? Do I need to have this mounted in my
intercooler piping? If so, can someone post pics of how they mounted it in their's. It was
just kinda stuck in my old intake.
97 S14
? @ 18psi (corn)
my build thread
Unbound Yuurei
Post by Unbound Yuurei »
HAHA i'm that guy that requested a engine bay pic!.... Noice!!!! your BOV looks exactly like mines. Did you fab the Intake Side Pipings as well? Haha sorry for the barrage of PMs >_<.
bmitchell_ga
Unbound Yuurei wrote:HAHA i'm that guy that requested a engine bay pic!.... Noice!!!! your BOV looks exactly like mines. Did you fab the Intake Side Pipings as well? Haha sorry for the barrage of PMs >_<.
Yea I ordered a couple bends online and fabbed that myself. I'm proud of my driveway fabbing skills. lol
97 S14
? @ 18psi (corn)
my build thread
Unbound Yuurei
Man i wish i had your skills >_<. I'm planning on ordering mine from enjuku. And are we going to see you crank to 20lbs? :o
bmitchell_ga
Maybe 15psi if I get bigger injectors. I'm on a stock motor still.
97 S14
? @ 18psi (corn)
my build thread
DrEaMeR_VaNg
bmitchell_ga wrote:Alos does anybody know what this is? I was looking at my old short ram intake and noticed it was still in there.
I just plugged it back into my harness. It didn't change anything though. I think it's the IAT sensor. Should I have this hooked up? Am I suppose to have this mounted in my intercooler piping? If so can someone post pics of hoe they mounted the their"s. I was just kinda stuck in my old intake.
That should be the IAT sensor. I swear when I don't have that plugged up when it's NA the motor doesn't turn over for some reason so I plunged a hole into my Injen intake. Ghetto rig!? LOL
Kouki.Love.
sicks13
Post by sicks13 »
You are running an OBD 1 jumper harness right?? if you are you don't need the IAT sensor, thats why it doesn't make a difference if its plugged in or not..
bmitchell_ga
Has anyone got any input on using the xcessive mani while still having s14 cams? I was really wanting to just clean up the bay. On the stock motor I'm sure I can't justify the need for one right now with my setup. But it would always be there when the time comes.
I wouldn't mind giving up a little power on the bottom end as long as I get some up top. The car dosen't feel as strong in the higher rpm's specially when shifting into 3rd right now.
97 S14
? @ 18psi (corn)
my build thread
bmitchell_ga
sicks13 wrote:You are running an OBD 1 jumper harness right?? if you are you don't need the IAT sensor, thats why it doesn't make a difference if its plugged in or not..
I didn't use a jumper. I did the OBD 1 conversion using the JWT pinout diagram with a 95 ecu. Same difference?
97 S14
? @ 18psi (corn)
my build thread
sicks13
Post by sicks13 »
Yeah.
Post by street_240sx »
Loving to setup. Made 329 HP on. Stock internals, gives me a lot more hope lol
all shal perrish
Post by all shal perrish »
PUSSY :)
i ran 23+ off my hx35 and 92 pump for quite a while, i still would but dont even get to drive the car anymore im so stinkin bussy with work
www.autovaughnperformance.com
if you have some, pm me
bmitchell_ga
PUSSY :)
That's amazing. I didn't think the stock motor would hold that much boost. Do you still have your security company? And I guess I am what I eat. :D
97 S14
? @ 18psi (corn)
my build thread
all shal perrish
yes yes and yes :)
Theo23
Post by Theo23 »
Nice build. Everything takes time.. don't rush any decisions and you'll be happier in the end!
My red '95 had a pin stripe like yours.. First thing I did when I got it home ( albeit, this was in '99) was remove the stripe. It will look 10 times nicer IMHO. It is weird tho that they didn't even follow the body line.
I hear ya on the in-bay pan removal.. not fun. My engine is out now too and I will also be fixing my bung's pin holes heh..
bmitchell_ga
Theo23 wrote:Nice build. Everything takes time.. don't rush any decisions and you'll be happier in the end!
Yea I've been wanting to take off that pin stripe since I bought the car. I was just scared I would have a red pinstripe underneath. That would probaly be better though lol.
97 S14
? @ 18psi (corn)
my build thread
Theo23
Post by Theo23 »
You may have a tan line, but a quick buff would probably blend it in alright.
bmitchell_ga
Profec B came in today
Wow this thing is smaller than I thought it would be.
97 S14
? @ 18psi (corn)
my build thread
katrecipe
**BANNED**
intercooler piping
Post by katrecipe »
i like the hot-side intercooler piping setup looks real good, in fact the whole car looks clean
I was a moron and I got banned!
bmitchell_ga
Didn't get much done this weekend cause of the wifes b-day. But today I removed my intake mani and started taking off evap and egr stuff. No emissions in GA ftw.
How you like my labatory haha :)
97 S14
? @ 18psi (corn)
my build thread
Kamilitaryman
Post by Kamilitaryman »
bmitchell_ga wrote:Didn't get much done this weekend cause of the wifes b-day. But today I removed my intake mani and started taking off evap and egr stuff. No emissions in GA ftw.
So clean! I like it a lot! I can't wait to own my own house....
Build looks great btw.
bmitchell_ga
Well I decided to skip on getting the xxr 527's. And finally decided to go 5-lug
New shoes
Mb battles 17x 9.5 +15 wrapped in Nt05 rubber 235/40's and 255/40's
97 S14
? @ 18psi (corn)
my build thread
