Project Frankenstein Superleggera
The project will consist of a frame like the Ariel Atom and will weigh around 900-1200 lbs.
The Uprights and Brakes will be from a Miata, A arms are custom made. The engine is most likely going to be SR20, I know why. The reason of the engine choice is because every pound counts and the differance between KA and SR is about 61 lbs. I was looking at a GTIR SR20, then use a FWD trans. The entire price of the car is $6500.
When Cornered, What G's Can You Pull
- Walperstyle
I've been thinking of doing one too. I think it would be fun. There is a lot of stuff to take into consideration though. The new arial atom has a v8 and its not quite as good as the first because of the added weight in the rear and the extra power make it to hard to drive. Good luck!
95 Nissan 240sx
5 speed
300zx LSD
HKS High Power Exhaust
5 speed
300zx LSD
Thanks guys for the support. The suspension geometry doesnt need to be spot on, most of the custom cars ive watched being built and there A arms were horizontaly. But if I cant find the angle of the Atom's A arms, then I will copy the miatas. The coil suspension will be off a R1 bike and I will be setup in a Pushrod configuration
This isnt to dicourage anyone on there current project or/and car. this is just to show you what im looking at on a daily basis
Pushrod Suspension
Here are some other car designs
VSTORM
SUPERLITE ROADSTER
DERONDA
and a new company
MATRIX MOTOR WERKS
Pushrod Suspension
VSTORM
SUPERLITE ROADSTER
DERONDA
and a new company
MATRIX MOTOR WERKS
I've always wanted to do this. With a sc ka, it would be naaaaasty.
- tom550
yea today was horrible in ABQ. idk about clovis but at least here it will be a raining one min then 2 min later there wont be a clud in the sky then.1993ka24det wrote:If i was back in FL i would worry about the rain. But since Im in New Mexico Im not worried about it. Im worried more about getting sand blasted
but i really like the MATRIX MOTOR WERKS frame design.
you have cluds in the sky where you are at? strange. we usually have clouds where I live when it rains.tom550 wrote:yea today was horrible in ABQ. idk about clovis but at least here it will be a raining one min then 2 min later there wont be a clud in the sky then.1993ka24det wrote:If i was back in FL i would worry about the rain. But since Im in New Mexico Im not worried about it. Im worried more about getting sand blasted
- TanManS14
This thing is just sick. When i grow up, i totally want to have one. GTM super car is where its at.
http://www.factoryfive.com/table/ffrkit ... llery.html
does anyone know if you can convert a linkage type trans to a cable shift or if when you transfer the engine from a fwd to a mid engine setup. will the shift linkage be useable as tha mid engine. PS the car will be RHD since I dont have to F around with dashes or firewalls.
if you use a qr 6speed trans, it is already a cable shifted trans,1993ka24det wrote:does anyone know if you can convert a linkage type trans to a cable shift or if when you transfer the engine from a fwd to a mid engine setup. will the shift linkage be useable as tha mid engine. PS the car will be RHD since I dont have to F around with dashes or firewalls.
also... is everything but an engine/trans included for 13k?
yes I stated that last night, and does the QR tarns bolt right up to the SRnx2000det wrote:if you use a qr 6speed trans, it is already a cable shifted trans,1993ka24det wrote:does anyone know if you can convert a linkage type trans to a cable shift or if when you transfer the engine from a fwd to a mid engine setup. will the shift linkage be useable as tha mid engine. PS the car will be RHD since I dont have to F around with dashes or firewalls.
gotcha1993ka24det wrote:yes I stated that last nightnx2000det wrote:if you use a qr 6speed trans, it is already a cable shifted trans,1993ka24det wrote:does anyone know if you can convert a linkage type trans to a cable shift or if when you transfer the engine from a fwd to a mid engine setup. will the shift linkage be useable as tha mid engine. PS the car will be RHD since I dont have to F around with dashes or firewalls.
only thing needed to make the qr trans bolt on the sr20 is the p12 bellhousing.
or you could just buy a p12 trans that is imported.
but it wont be locking.
but you can use the hlsd from the qr to swap into it.
Thats what im doing for my bluebird motor in my NX.
the matrix motor werks is selling there hayabusa powered car BEC
http://cgi.ebay.com/ebaymotors/Replica- ... ucks#v4-38
