ka24e-t need an experts help
ok so I have my ka24e-t set at 32psi of fuel and with 450cc injectors with jgs tools resisotors and stock maf! when i crank it fires up and runs at idle for about 10 seconds then dies, Then i start again same thing. Then again I hit the gas and it revs till about 4 or 5k then starts stuttering and just instantly dies. I dont know what to do I have a safc2 currently on it and have no idea where to start on that thing and the car wont even stay runing long enough for me to tune it! BTW i put fresh 93 in it so gas is good and I donty have a o2 sesor in it right now because my exhaust is being made and its open turbo right now ANY HELP WOULD BE AMAZING!!!!
Boost gets you laid
I'd say wait till you have everything put together. Missing sensors/parts always cause trouble. For example, the person I bought the current project from, thought that you didn't need charge pipes on the car to make it run properly. Hello 14-16AFR, was even on his gauge, apparently he knows nothing about lambda....sooo yeah, i threw it together and hello 12afr un-tuned.
Bottom line, assemble everything first. Then check for issues, and have someone who knows what they are doing setup your SAFC2 or do lots of research.
- Jordan Gladman
