Oil feed from sandwich plate
sodel_s13
Post by sodel_s13 »
Hi,
I have a ka-t, built. eagle rods, wiseco 9-1, walbro, ported polished head etc.
My car keeps blowing turbos one after another. Im running my oil feed line from a sandwich plate, is anyone else experiencing these kind of problems with enough oil supply? yes, i am running a restrictor on a an -4 ss line. what should i look for? Im pissed, its like my 4th t25.
thanks!
joshpntbl07
Post by joshpntbl07 »
im running a -4 line from my oil sandwhich with zero problems. i put a inline adjustable restrictor but have had it all the way open with no issues. and its a journal bearing.
if your built, why not go with something bigger than a t25?
sodel_s13
Post by sodel_s13 »
My restrictor size is like 1.1mm. where did you get the adjustable one?
t25 because im poor. haha i want a t28. i use the car for drifting, not looking for big numbers, just something that will give good response.
joshpntbl07
i got it from a buddy, but you can find them online. its just a valve you can adjust how open it is by turning a knob on the side of it. i have it all the way open though (no restriction). i would take the restrictor out of the line and see how it does.
i bet you would like my turbo. garrett t3/t4 50 trim, .58 hot side. quick spool and good for around 430hp. i paid around 400 brand new.
emo_tactical9
Post by emo_tactical9 »
Are you sure it is filtered?
sodel_s13
Post by sodel_s13 »
Im not sure, if you're reffering to me. might up drill the hole bigger. Will update this soon,
Jordan Gladman
Post by Jordan Gladman »
Sandwich plates are not filtered. Get rid of it. I burned up 2 turbo's running a sandwich plate. You might get away with it running an older motor but a new motor will run a ton of metal particulate from break in through your turbo.
biggie
Post by biggie »
Drifting and running the T25 at high rpms on too big of motor can't be helping them.
'93 Coupe GT32e/'93 Vert/'03 G35C
Always Broke!!!
bmitchell_ga
Post by bmitchell_ga »
biggie wrote:Drifting and running the T25 at high rpms on too big of motor can't be helping them.
+1 How much boost pressure are you running?
97 S14
? @ 18psi (corn)
my build thread
sodel_s13
Post by sodel_s13 »
How should i run my lines then? its only off wastegate at 7psi. i've heard mixed opinions on running the sandwich plate or not.
Post by sdaigle240 »
Jordan Gladman wrote:Sandwich plates are not filtered. Get rid of it. I burned up 2 turbo's running a sandwich plate. You might get away with it running an older motor but a new motor will run a ton of metal particulate from break in through your turbo.
what jordan said. i rebuilt my motor, did the first oil change like REALLY quick, maybe 50miles. and killed my turbo by the first 500mi. I am now tapped into the spare hole on the filter neck AND running an inline filter. now i can sleep at night.
remove filter
removet the "filter neck" attached to the blok with 4 bolts
remove the spare plug from it. i had to drill and ez out it.
its bsp thread, buy a bsp to -4 fitting from pegasus racing.
be REAL careful about metal shavings and what not.
sodel_s13
Post by sodel_s13 »
is that port filtered? its before the oil filter. maybe i should get a inline oil filter?
joshpntbl07
oh, i was under the impression that the oil coming from the plate had already gone through the oil filter. guess ill be ordering an inline filter.
biggie
Post by biggie »
That port on the oil filter block is filtered. Just a sandwich plate is not.
Always Broke!!!
yup. and u can get fine screen filters on ebay for like 12$. moroso is like 70$. i got it and am happy its like kanguwanga or some crazy brand like that search -4 an in line filter, its black. i ordered pre made lines from pegasus too. the added inline filter is perhaps over kill being double filtered but it didnt cost much more for the filter and 2 lines instead of one. FYI youg going to need a 90* off that filter neck and its a TIGHT squeeze between the motor and altinator. i slipped a rubber hose over it to kinda wedge it in place and avoid wear from vibrations.
