As the title states, my freshly, fully built KA24DE blows what is now a small cloud of smoke over a period of about 10 seconds during startup. It looks white when it first comes out (could be the few ounces of seafoam I put in the crankcase with the oil change) and then goes bluish as it gets less dense until it finally goes away and won't come back during driving/idling/etc. It only happens when it is cold. It has started doing this over the past week or so and is getting worse, though the car runs great otherwise.
I'm familiar with this issue as it typically involves the valve seals but the head is fresh too. I didn't do it myself, I had a machine shop deck it, grind the valves, and put in new valve seals. Is it possible it's just a shiddy job? I've had several things done with this guy over the years and he seems to do good work, but I don't know...
Compression is good and still rising as it's breaking in, i think it's at about 170psi right now warm across all cylinders if not higher. I haven't checked it in about 60 miles or so.
Head gasket should be fine as coolant and oil are definitely separate, I observed this last week when I changed oil and drained coolant to put in a thermostat. I have seen the temp gauge at the notch before the H (showing like 245f or so in Nistune) for no more than 15 seconds before I shut it down (facking gay Stant thermostats...pieces of junk) - which has occurred probably 5 times but I don't think that would cause any issue.
During the initial tuning stage to adjust for my 85lb injectors N/A, I knew it has run rich during cruise and idle which I have since ironed out, but I don't think that would affect anything.
Any idears?
Fresh build, smoke on startup then disappears
- Jordan Gladman
If you can pull your intake manifold off your motor - cold. You can check and see if oil is puddling on the intake valves. When my stem seals were bad, there would be a sizeable amount of oil sitting on the valves ready to go into the cylinders on start-up.
That's a pretty good idea. I'll give that a look.Jordan Gladman wrote:If you can pull your intake manifold off your motor - cold. You can check and see if oil is puddling on the intake valves. When my stem seals were bad, there would be a sizeable amount of oil sitting on the valves ready to go into the cylinders on start-up.
Kfred, how much did it smoke? Like I described it's a pretty good-sized cloud.
- Kfred
Pretty nice little plume. Enough to be embarrasingairman wrote:That's a pretty good idea. I'll give that a look.Jordan Gladman wrote:If you can pull your intake manifold off your motor - cold. You can check and see if oil is puddling on the intake valves. When my stem seals were bad, there would be a sizeable amount of oil sitting on the valves ready to go into the cylinders on start-up.
RIP Nate(480sx)...
