KA24E Getting to much fuel w stock injectors?
Ok I havent posted here in a long while but I have been very busy. I order a poop ton of parts for my sohc. here is the list.....
Performance Engine Rebuild Kit from IPP:
Includes..
Wiseco Stock size dished pistons
every seal/gasket you need for the whole engine (which was freakin awesome)
Custom Machined copper Head Gasket (30psi)
Main bearings
Rod bearings
High volume oil pump
I also bought....
Eagle H beam rods
Port and polished head w 3 angle valve job
Colt triflow 2 cam
All timing components from the sprokets to the chain tensioners
timing chain cover
Xcessive Man. Intake plenum
Act High Performance Clutch
I finally strated the rebuild everything went smoothly. It is all back together and in the car, but................. you guessed it .. It wont start.
For some reason the cylinders keep flooding with way to much fuel. I don't know what the hell is wrong. The timing is dead on Myself and and two professional mechanic checked all the timing indications and settings. They are spot on.
JORDAN I need you bud if you have any idea please help me out. Oh and you too Mark I know youre out there too.
Includes..
Main bearings
Rod bearings
I also bought....
Eagle H beam rods
Colt triflow 2 cam
timing chain cover
kcuf toilet bowl racing!
- Jordan Gladman
Almost sounds like you're getting a full out MAF signal. Are all the cylinders flooding or just 1 or 2?
Are you running an S-AFC? if so, what does the AF% say at start up?
Ok i have a few theories.
I've read that the o-rings on the injectors could cause the flooding. Supposedly if they are messed up then way too much fuel gets in the engine.
OR
When i installed the crank pulley and tried to torque it of course the engine turned over.So I spun the engine over to set it at tdc per the pulley. The timing chain was on correctly and at tdc before i turned the engine over. When i set the engine at tdc by the pulley I think i may have actually set it on the first timing mark not the second mark. Would that cause my problem?
OR
Ok I've got more theories for things that may cause my severe fuel flooding issue.
1. The Engine/Coolant temp sensor may have gone hay wire on me. I have track this sensor down through some posts, and supposedly if this sensor goes bad the ECU resets to a factory preset. this preset show the engine being colder than it really is. So to warm up the engine the ECU dumps more fuel than needed thus flooding the cylinders.
2. TPS sensor.... Appearantly the previous owners of my car did a engine swap. The new engine ( the one I have now) must have been out of a auto but my car is a manual. When I hooked the wiring harness up I made sure as usual to plug all connectors in. The TPS sensor, from what I gather, is different between the two auto and manual. If I plugged both connectors into the Auto tps sensor then its sending a false reading to my ECU. It's telling my ECU that the throttle is wide open when it's not.
3. MAF Sensor.... If this is F'ED then it could be sending incorrect signals to my ECU. I highly doubt this but it could be a factor.
Let me know if any of this sounds like I may be on the right track.
My car is at a friends house two hours away and thats why I can't test all this out personally.
Took codes from the ECU finally. The only code I got was 13 and that is the engine coolant temp sensor. Hit up O'Reilly's and replaced it. Still no help. I guess I need to grab a FPR and replace that. I really doubt that is what would keep the car for starting at all. With a bad FPR I would think the car might run poorly and rich but not cease to function period lol.
I'm going mad with this problem ...... I just can't figure out what it could be..... Someone has had to had this problem before. I'm still taking suggestions.
Another update. I went home last night and ripped into my intake plenum and manifold because i just wanted to look for fuel possibly pooling in the intake. Well I found alot more than just fuel. I had a concocsion of fuel+antifreeze+oil pooled up like an inch deep in myintake manifold. IDK how antifreeze got into my manifold. The only thing about this that helps is i know why the engine won't start...... All gaskets and seals have been replaced. My headgasket isn't blown because the engine hasn't even started yet. On top of that I have a solid copper headgasket. The Timing Chain and components have been replaced so its not getting into my oil that way. I'm thinking I hada line mixed up or something.
