ECU PINOUT DATABASE
ECU PINOUT DATABASE
I would like for a moderator to place this as a STICKY or in the TECINFO section. This is very helpful information. This site has the ecu pinouts for many different cars, as well as OBDII, OBD1 and pre OBD 240sx's.
http://www.plxdevices.com/ecudatabase.htm
For reference, here are the extras. Taken from 89-94 USDM 240sx FSM. No guarantees on accuracy. Also note that the ECU connector shown on the above website is pictured from the harness side, or looking into the ECU.
!EN is active LOW output: when this pin is low(ground) the device will then enable/turn on
!IN is active LOW input: when low(ground) this signifies the device is active.
1: power transistor NPN base output
3: to dropping resistor to NPN collector
8: EGR Temp Sensor
9: condensor fan !EN
11: AC condensor !EN
12: A/T
22/30: CPS Signal 1
24: CEL !EN
25: Swirl Control Valve sol !EN
27: Knock sensor input
28: A/T
31/40: CPS Signal 2
33: 5th gear !IN
34: Start signal in (12V)
35: Neutral !IN
37: TPS 5V
41: Thermo Amp
42: 4th gear !IN
43: Power steering pressure !IN
44: Rear window defog !IN
45: Ambient Switch / IACV-FICD !IN
102: PAIR sol !EN
104: Fuel pump relay !EN
105: EGR sol !EN
113: IACV-AAC PWM signal
8: EGR Temp Sensor
12: A/T
22/30: CPS Signal 1
24: CEL !EN
28: A/T
31/40: CPS Signal 2
33: 5th gear !IN
35: Neutral !IN
37: TPS 5V
41: Thermo Amp
42: 4th gear !IN
102: PAIR sol !EN
105: EGR sol !EN
- UNISA JECS
This one should be pretty accurate I went threw the 91 wiring diagram, I did find a few in inaccuracys from other pinouts, cant remember which ones but this is pretty much straight out the 91 FSM.
Rep/Feedbacks
http://www.zilvia.net/f/showthread.php?t=134726
Z32 E-Brake/Parking Brake Heatshield Assemblys!!!
http://www.zilvia.net/f/sale-items/1667 ... plete.html
Rep/Feedbacks
Rep/Feedbacks
- 13waynegarcia
The new link is here:13waynegarcia wrote:that link doesn't work anymore
http://www.plxdevices.com/support/ecupinoutdb.html
Cheers,
Dave
- Walperstyle
