*Post Your Engine Bay Pics*
I know I'm ages late, but to answer your Q, my radiator was slanted to join the Intercooler in the shape of a V. Creating it's own duct to trap air in between my radiator and Intercooler. I'm redoing the setup with a bigger Intercooler and using sheet metal to fabricate a duct to get more air in. Hope that helped.emo_tactical9 wrote:How did you do the ducting on that?turbo_dreams wrote:
Gave me two good years, only got to drive her for 3 months after i overhauled and wire tucked the bay, r.i.p piston rings. I'LL BE BACK ![/img]
- Mark Washington
- Mark Washington
This is the daily. Fully built CP,Eagle,ARP,ARP,Clevite,Two 91 Exhaust cams with JWT gears retarded 1* and back cut oversized valves. Walbro 255,SAFCII 370cc Q45 injectors,MSD 6al and blaster coil nology wires OEM cap and rotor,Timing advanced 16* Pacesetter header with MR gasket and Stage 8 locking fasteners on the real Apexi N1 with a magnaflow cat to keep noise down and pop off throttle. It also has B&M Shifter and a pretty cheep ACT 6 puck clutch that slipped on my ka24ET, but works fine for this car. Oh yeah xcessive intake manifold (Thanks Rich!!) Q45 Throttlebody.
I am not using an Idle control valve or any EGR smog crap, but I still use the charcol can cause it keeps the smells down.. Since its a daily driven car. I wanted 240HP from it but failed
most likly from the low compression and the fact that none of the mods really make gains for a N/A aplication. The AFR's were good and it starts right up in cold mornings doesnt have any cooling issues and really feels grunty for what it is.
[IMG]http://i945.photobucket.com/albums/ad29 ... ton/na.jpg[/IMG]
Somone please post this pic. My account wont let me. Thanks. Just wanted to share this even though its not turbo. It will get boosted, I just wanted to make sure it ran great before chasing those issues.
速い速い シルビア ターボターボ
- emo_tactical9
Mark Washington wrote:
- Mark Washington
- shift_down
Hey emo, have you ever thought about relocating the battery to where the filter is, and relocating the filter to where the battery is? Makes more sense than to route air in front of a hot engine. Or am I wrong?
Here is my toy!!! Finally drivable
Eagle rods; Wiseco dished pistons; balanced rotating assembly; Supertech valves, springs, retainers, seals; 248/248 cam swap w/ JWT adj sprockets; ACT 6puc clutch; 11lb flywheel; GT3582r journal bearing turbo; 600cc JECS; Godspeed intake manifold; Cometic .075" head gasket; ARP studs upper and lower engine; Maxima coil on plug conversion, xcessive distributor delete cap; AEM series 2 = 404whp 316ft lbs torque
My green kouki ls1 engine bay.
My red zenki engine bay. (mafs is now blowthru)
1995 S14 daily built block nismotronics sr20det Ecu running my ka-t, synergy green S14 5.3l turbo 240sx 1/4 mile traps 135mph on 13psi and dr's.
Holset HE341 Install thread woohoo!!
viewtopic.php?t=48692
http://www.playloudclothing.com/
