How to set TPS soft closed point correctly?
Postby schmauster920 » Mon Jul 16, 2012 6:02 pm
I warmed the motor up, unplugged the TPS, started it, revved it over 3000 rpm 4 or 5 times, turned it off, plugged the tps back in and restarted it.. I assumed this sets the TPS soft closed point for the ECU.
It wont go lean when closed throttle and coasting, i can turn the TPS down to about .43 volts and it will switch to 'closed throttle' in consult and it will cut fuel when coasting, but it leans out strangely at low throttle sometimes, not if its in the voltage range it should be. (.45-.550) i believe
Im going to leave the battery cable off for a few hours and see if it resets.
Postby thesandman4444 » Mon Jul 16, 2012 10:48 pm
to reset the tps idle unplug with the ignition on, switch off then back on and plug it back in. Is it an oem tps? The parts store replacements have slop in them and it messes with the low throttle and tps closed point.
built block, sls manifold, 60 trim t3/t04e, rc 750s and nistune
thesandman4444
Postby schmauster920 » Mon Jul 16, 2012 10:50 pm
Thanks for the info, ill give that a shot tomorrow.
Its an OEM tps, ive heard bad things about the aftermarket ones too.
Battery cables off for 45 mins didnt reset it.
Postby adamky » Wed Jul 18, 2012 7:20 am
thesandman4444 wrote:to reset the tps idle unplug with the ignition on, switch off then back on and plug it back in. Is it an oem tps? The parts store replacements have slop in them and it messes with the low throttle and tps closed point.
Listen to this guy. I followed his tip when troubleshooting my own TPS issue and this fixed it.
Postby schmauster920 » Wed Jul 18, 2012 9:45 am
Heres the link adam is referring to.
http://www.ka-t.org/forums/viewtopic.ph ... 1b252c458d
I left it unplugged for a few secs, ill have to try it a little longer this time.
Postby schmauster920 » Sat Jul 28, 2012 10:32 pm
Update:
Couldnt get the TPS idle light to reset maybe my idle was too high.
I finally used techu to reset the fuel trim history and the TPS closed flag is working now.
Postby adamky » Tue Jul 31, 2012 7:56 am
That's weird. How high is your idle?
Postby schmauster920 » Tue Jul 31, 2012 11:15 am
It was around 900, and warmed up. i dont have an IACV, maybe that messes with it. I tried it quite a few times, and different ways while watching in consult.
I was getting detonation at 13degrees and 8psi, after setting the soft point i am now at 14 and 17 degrees, no knocking :D Feels like real KA now. Too bad my turbo is taking a dump now lol
Not to mention im back to 25+mpg rather than 20
Postby Ikera » Tue Oct 23, 2012 6:17 pm
I don't have consult cable, but I have SAFC II if it shows 0% throttle does that mean the ECU is also taking i as a 0% or SAFC has it's own values based on voltage reading?
Ikera
Postby schmauster920 » Sun Oct 28, 2012 11:20 am
The safc makes its own % from the throttle voltage it sees, so its pretty useless as far as diagnosing. You should do the timing setting procedure and it should reset the tps closed point.
Postby Ikera » Tue Oct 30, 2012 12:34 pm
thanks! I realized that just yesterday.
the SAFC will slowly adjust itself to 0% throttle if the RPMs are at 0
I don't think SAFC is completely useless for diagnostics, it does have a volt meter feature. I'm not sure how accurate it is, but it sure is a quick and easy.
Ikera
Return to KA-T Tech. Basic
Users browsing this forum: Google [Bot] and 94 guests
