609hp/512tq @ 20 psi
redlineracer21
Post by redlineracer21 »
Went to a dyno day on saturday. Was very suprised to see it make that much power at 20psi on a s366 turbo. The dips in the graph are missfires. The alternator wire was loose and i think fell off at the end of the pull...
FlatBlack
Post by FlatBlack »
Good god.
Well done.
89 240SX Coupe
02 GMC Sierra Z71 5.3L 4x4
03 Kawasaki 636 ZX-6R
77 Honda Trail 70 140cc swap
Post by schmauster920 »
Great numbers for sure, looks like a blast once you pass 3k lol.. you might have been getting blowout from the lower voltage to the coil
BADA$$240
Post by BADA$$240 »
Impressive numbers man.
92 240sx RB25DET
07 R6
12 Mazda 2-all around beater
Post by supakat »
Nice numbers.
ALTKAT96
Post by ALTKAT96 »
What fuel are you running?
Post by airman »
Sweet numbers. I'm guessing that's on ethanol?
turbo2nr
Post by turbo2nr »
awesome numbers
what the specs on your build? t3 or t4 s366? what a/r
i may have to change turbos now lol
R.i.p. 97 s14
96 s14 ka-t
redlineracer21
Thanks everyone! The car runs on pump e85.
Basic specs are:
9:1 comp pistons
Bc 272 cams with dual valve springs
Custom intake
95lb/hr primaries
165lb/hr secondaries
Cbr 600f4i coils
Custom exhaust manifold and downpipe
Aem ems series 1
S366 t3 .70a/r v-band with bullseye powers billet comp wheel
Video on the dyno:
http://youtube.com/watch?feature=plcp&v=A5XOjx3td7o
ALTKAT96
Post by ALTKAT96 »
Good **** man!!
bmitchell_ga
Post by bmitchell_ga »
Might sound dumb, but could you elaborate more on your head setup? I see springs and cams. How bout valves, valve job, spring seats, keepers. Stuff like that please. Or stock with just cams and springs?
Reason asking i, I'm getting ready for a rebuild. Thanks
97 S14
? @ 18psi (corn)
my build thread
Post by picsbypenny »
what fuel pump or pumps do you run?
redlineracer21
no problem
heads been clearanced for the bc 272 cams
cams have been degreed to the least amount of overlap with jim wolf cam gears
Supertech cam followers (shim under bucket design)
Supertech dual valve springs and retainers (the 96lb spring pressure ones)
Stock valves and stock porting
Fuel pumps are 2 walbro's (high pressure ones)
-10 feed line (overkill. -8 is plenty enough)
-6 return
aeromotive regulator
-10 sxperformance fuel filter[/quote]
ammfab
Post by ammfab »
good god..... u ever come out to the meets on 35th and union on the weekends or when it was at 43rd and camelback???
mike
redlineracer21
I use to go out to 35th and union. Haven't recently. That was back when i had this setup in a maroon s13.
t66-240
Post by t66-240 »
I'd like to see this in person. I'm in Laveen... what part of Glendale are you in?
Are you on az240?
Mike
97 Altima (stock)
05 350Z touring powerlab turbo
93 240SX coupe not so stock
543.26 rwhp 463.88 rwtq
Mike Lee
Wmcleverly
Post by Wmcleverly »
im here in glendale. I am on az240..im trying to get a meet together on the 30th...lets get some KA-T's involved here....
Eagle rods; Wiseco dished pistons; balanced rotating assembly; Supertech valves, springs, retainers, seals; 248/248 cam swap w/ JWT adj sprockets; ACT 6puc clutch; 11lb flywheel; GT3582r journal bearing turbo; 600cc JECS; Godspeed intake manifold; Cometic .075" head gasket; ARP studs upper and lower engine; Maxima coil on plug conversion, xcessive distributor delete cap; AEM series 2 = 404whp 316ft lbs torque
redlineracer21
Not really on az240. Mostly drifters and im not really into that. I just go on there for parts :D
I'll be out of town on the 30th. I wanted to go to that meet but doesn't look like i will be able to.
If school allows me :roll: i will probably be out this weekend at the local meets.
riodcs
Re: 609hp/512tq @ 20 psi
Post by riodcs »
Congrats, how is the tranny holding up?
396.1 whp on GM8
Rb26kouki
Post by Rb26kouki »
Fuhh that's good power for 20psi
ka240de
Post by ka240de »
hey I am extremelybcurious about those supertech cam followers are they worth the price? Thoughts? Results? Would be much appreciated
Never seen someone running them before
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
BoBaCk1
Post by BoBaCk1 »
What head gasket you running ?
Built ka-t
Arias 8:8:1 .20 over
K1 rods
Arp head,main,rod studs
Kelford 272's,dual valve springs
Precision 6262sp .82a/r, peakboost manifold
Cxracing fmic
Fuel injector development 2000cc
Proefi pro128, e85 flex fuel
Rb25 flywheel, dxd 350z clutch
ka240de
Post by ka240de »
10mm arp's ? what headgasket. i have my head off and im thinking maybe upgrade to cosworth and dont know if i need to upgrade headstuds ..
Post by street_240sx »
What Arizona?! Me too lol gotta love local ka-t
ka240de
Post by ka240de »
Do you have any graphs without the dips ?
