Turbo2nr's 600hp build (vmount/wiggins/fuel/custom fab)
Just throw in straight up lucas to hold you over. That is what I did when it started to whine.
Granted pure power can shear the gears but most failure is from tranny shock. Just baby it by going into gear easy then romping on it. I used Lucas cause it said you can put 50% in with existing oil. I also used thicker than 85w-140 before the Lucas. When it is cold, it would be stiff but after it warmed up, it was smooth. I also noticed my shifter was cooler than any less weight I had in their. But I used the thicker oil to help avoid tranny shock and it lasted me +3 years. I ended up blowing a tranny while n/a but I was clutch kicking and beating the piss out of it.
- bmitchell_ga
Im very intresred in the vq tranny setup. Please document it wel.l
97 S14
? @ 18psi (corn)
my build thread
? @ 18psi (corn)
my build thread
Just regular ole Lucas Heavy Duty Oil Stabilizer.
Says you can use 25%-50% in manual gearboxes so I did and some more.
http://www.lucasoil.com/images/medialib ... zr_1_2.pdf
Finally made it to Tarmac now the real work beings
agenda:
install fuel setup ( dual pumps/s.s. lines from tank/fuel ral ect)
custom intake mani insall
pcv catch can setup
v/c catch can setup
custom fmic + pipes + wiggins or vmount
custom 3.5" exhaust
new harness
aem v2 + sensors
z32 rear brakes
my wallet is going to love me
agenda:
pcv catch can setup
v/c catch can setup
custom 3.5" exhaust
new harness
aem v2 + sensors
z32 rear brakes
R.i.p. 97 s14
96 s14 ka-t
- bmitchell_ga
You kept your battles
97 S14
? @ 18psi (corn)
my build thread
? @ 18psi (corn)
my build thread
- bmitchell_ga
Mighty find hardware. Are you in "construction "?
97 S14
? @ 18psi (corn)
my build thread
? @ 18psi (corn)
my build thread
I agree that's mostly the case. I know that kedbmx was rolling into the throttle when he sheared the teeth off of his third gear. I'm not sure about T2T. With a good clutch that doesn't slip, traction, and 550+ whp, the tranny is a ticking time bomb, even when rolling into the throttle (no tranny shock).supakat wrote:Granted pure power can shear the gears but most failure is from tranny shock.
That Full Race mani looks so damn good with that ceramic coating.
Tranny shock is the #1 culprit of damaged trans. If your going to make serious power/Tq then go with solid diff bushings and a clutch that will provided the minimum amount of stress on the trans. I have seen stock trans (referring to R154) hold up to some serious power as long as the stress is minimized on the trans. For those of you that may not know the R154 isnt typically recommended past 600-650 lbs/tq yet I have seen them hold up to much more as long as the driver isnt a dumb ass and the stress is minimized mechanically.
Cant wait to see her done Drew.....and trust me I know how you feel about the pockets. My standalone is about 75% of the total cost of my car when I bought it in 2002
- picsbypenny
^right after we RWB your 911,
slight update:
fab started on v-mount, every thing is looking awesome. Big thanks for Tarmac and damian for all the fab work!
mounts
fitment
hot side end tank
hot side turbo elbow
modifying gtx housing
wiggins weled on!
cold side end tank
intercooler weled
long way tp go..
slight update:
mounts
fitment
hot side end tank
wiggins weled on!
cold side end tank
intercooler weled
long way tp go..
R.i.p. 97 s14
96 s14 ka-t
stoped by the shop last night for some late nite fab and beer!
started on the rad. hard piping, Damian is the man when it comes to figuring out these damm angles and flow..
quick look of how short the charge pipe will be once the winggins are on
intercooler came out legit, ETS hooked it up!
as she sits..
as she sits..
R.i.p. 97 s14
96 s14 ka-t
- picsbypenny
- Irresistible
- Kamilitaryman
Cool, interesting and unique setup. Thanks for posting the pics.
thanks everyone
what color an fittings ?
im using black nylon lines for the bay,
im leaning toward the black/red, i think the blue/red is classic but way to many colors going on in my bay with polished/purple, flat black ect..
the black and silver is nice to but kind of plain IMO
R.i.p. 97 s14
96 s14 ka-t
- Kamilitaryman
Go with colors of your country's flag.
