I was driving and my car just decided to die. So I pulled over and check fuel, plug blah blah. Then I checked my maf, and the car idles without the maf. The i put a multimeter to it and it reads 2.7 volts with the car off, and 3.7 volts with the car idling. Soo is there anyway to fix this?
I cleaned it with maf cleaner.
Regards
Rojo
Is there anyway to fix a maf?
Likely it has croaked - there is circuitry inside of it and it's likely that the board has gone bad. Not sure how to repair that.
- R34SR
throw it away, go map.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
Mazworx z32 tranny swap
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
^ Easier said than done - to the OP: going to a MAP would require a standalone ECU like Megasquirt, AEM, Haltech, etc which can be costly.R34SR wrote:throw it away, go map.
2.7v idle is a bad MAF. It will need to be replaced with a good one - sorry for the bad news!
- R34SR
Yea I know, I god fedup with mafs, even reman ones would eventually die on me, just said eff it and got ms2 pnp, not sayin its feasable for everyone tho
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
- Walperstyle
You can run both with MS but it does not make sense quite honestly especially when I am planning on throwing 25psi into my motor shortly. The MAF would blow its hat off. But I did epoxy my n62 and it held with 20psi just fine.
- shift_down
Hey you know that circular mesh type filter in the maf housing? Is that a necessity if theres going to be a filter at the end of the maf? Im trying to cut the maf down a it to make some room, I was thinking of removing the mesh and trimming away at the plastic.
I know on my NA '93 Altima, the mesh provides a laminar airflow that helps keep the MAF/readings happy.
I've run a 'hybrid' intake on the car for years with a KN cone filter bolted to a maf adaptor inside the airbox (to reduce heatsoak) but it required removing the mesh.
I finally ditched that setup late last year after finally realizing that it was causing my idle to fluctuate noticeably and car was going rich (after ruling out everything else over a few months and many gallons of unburned gas lol)
That's all I can say since I'm not FI currently....
