Turbo Selection poll/thoughts 450-500hp
Which turbo would you choose?
Poll ended at Tue Apr 09, 2013 8:53 am
Big Holset H1C
0
No votes
Holset Hx35w
6
60%
Precision 5031e
1
10%
Turbonetics T3
0
No votes
ghetto rig 10 yard blowers!!! JK JK
3
30%
Total votes: 10
tacokiller07
Post by tacokiller07 »
Hello everybody! This is my first post and im hoping i dont get flamed right off the bat lol. I was kinda wanting everyones opinion on a couple turbos so its more of a poll. I am currently putting together parts for a build and am looking at a couple turbos for sale, I want to make around 450-500 whp and just want to know which turbo from the choices below you would choose. These are my choices right now based on the price and me being poor :cry:
The choices are:
Big Holset H1C
Holset Hx35w-8 blade
Precision PTB 5031e (.50cold .63 hot)
Turbonetics T3 60 trim (waiting on AR specs)
Post by sdaigle240 »
this is not a flame.
your broke.... maybe try 300whp? its a lot more fun having and using a mild setup than dreaming/saving/parts hording for a high hp build. also, this is one of those questions where if you have to ask.... well you know. reliable 450-500whp setup $5k+
tacokiller07
sdaigle240 wrote:this is not a flame.
thanks for the input, i did think about that also but basically all i need now to finish this off is the turbo, injectors, clutch and ecu managment so i figured id try and go for it. ive bought and horded most parts already lol.
ashy-larry
Post by ashy-larry »
Yea...
You'd probably have to shoot corn to reach those numbers reliably w/those turbos.
u got all forged internals, head work, cams intake mani etc? def required. still lots to spend though. say u get this turbo for 300
ecu 700-1600 (MS to AEM)
500whp clutch, $500+
stock pile of ka transmissions $XXX
fire hose injectors $600+
u could tone it down and get a similar turbo (maybe smaller hy35), a white bunny clutch $250, some sti injectors $200 and a nismotronic ecu $500
Post by cleantune »
I would recommend either an Rb25 or a z32 trans too. The life of the stock KA trans hangs in an uneasy balance in that whp range. I suppose it depends how it is driven too. If it is not abused (like droppin clutch and shift lockin through corners) and power is applied gently from a roll, one could possibly have decent luck with the stock trans.
I would maybe check out limits for axels, driveshaft and diff, If you haven't already.
Just a side note: 280whp in an s chassis car feels pretty quick; all about that power to weight ratio!
RosadoRacing
Post by RosadoRacing »
I voted for precision cuz I love there turbos but a budget and 500whp don't go in the same sentence. Get a turbo that'll give you room to grow like a 6262 boost 7psi and next year try 14psi with a better build after aWhile 500whp gets boring.
BoBaCk1
Post by BoBaCk1 »
I vote precision 6262 also . I love mine and I even have the .82 a/r turbine. I would recommend you use e85 if you can get it i swear its a god send bro.
Built ka-t
Arias 8:8:1 .20 over
K1 rods
Arp head,main,rod studs
Cxracing fmic
Proefi pro128, e85 flex fuel
boker240
Post by boker240 »
what sdaigle said.and there is a big financial difference between 300whp and 500whp.if u want reliability...
one of the holsets w do it though.should be around 300whp @ 15psi and 350whp @ 20.hx35 is good for 30 psi at least.
but ya id change ur goals strickly becuz u said the word poor.poor and hotrod doesnt go together idc w anybody says.
currently n/a.
Berserker
Post by Berserker »
6 puck white bunny clutch will hold 500whp easily, and That's 375$
