11.3 second pass VIDEO!
All about KA-T Drag Racing. Bragging, Timeslips, Results, Questions, Whatever
RosadoRacing
Post by RosadoRacing »
http://www.youtube.com/watch?v=lw-ygpdIT38
14psi 480whp shifting at 6500rpm
Badazzsr20
Post by Badazzsr20 »
very nice man!! that thing came out the hole like a bullet! nice stuff
RosadoRacing
Thanks yeah it spins allot I might have to lower the rpm but I like fighting wit the car a bit its fun im going Tom hopefully it runs better!
Berserker
Post by Berserker »
Haha great launch. I don't think my white bunny clutch would really enjoy a launch like that lol
Post by airman »
Wow that looks fantastic. That's what I want to accomplish with my 2014 build. I need to read through build thread.
RosadoRacing
Thanks for the comment airman
jholman05
Post by jholman05 »
It looks so docile until it launches... then the true beast comes out!
Looking good
southjrz240
KA-T.org Featured Ride
Post by southjrz240 »
great work
http://www.ka-t.org/cain.htm
91 Hatch KA-T with the help of TURBO240
BoBaCk1
Post by BoBaCk1 »
Sick launch what was the trap speed and 60 foot .
Built ka-t
Arias 8:8:1 .20 over
K1 rods
Arp head,main,rod studs
Cxracing fmic
Proefi pro128, e85 flex fuel
RosadoRacing
1.47 127mph
flip240
Post by flip240 »
that was an insane launch!! what was the other guy's times?
My setup: KA24DE-T
i_slide
Post by i_slide »
Like what everyone else said - Nice Launch!!! What suspension are you running in the rear? Stock?
RosadoRacing
Kyb agx shocks on softest setting with lowering springs besides that everything else in the rear is stock except LSD of course. The other guy ran 10.58 138mph his 60ft was I believe 1.8 I spoke to him after the run hes on 38psi 740whp. I know I can run 10.5 with 550whp 22lbs
ALTKAT96
Post by ALTKAT96 »
What is the A/R on the exhaust housing now?
RosadoRacing
t4 .68
Post by shift_down »
That's so awesome! That launch was sick!
jaysol92
Post by jaysol92 »
i was in the bleachers when you were running the car. i gotta say the car sounds incredible in person
RosadoRacing
Thanks. I'm going to summer nationals at etown June 30. This time on 25lbs 650whp should run low tens
jaysol92
Post by jaysol92 »
Nice! Hopefully with all that added power your car will snap from the start like before. it was such a tastey launch lol
neverlift
Post by neverlift »
what rpm is your launch control set to? that was a very hard launch! :D
jaysol92
Post by jaysol92 »
I'm actually curious about the launch control too :)
RosadoRacing
I run the slicks at 11lbs mght go 13 since I snapped a axle but the car consistently does 1.4 the anti lag is 6200 -9 degrees timing 15% fuel. I'll keep ya posted hopefully heading back out in a few Weeks 9s would be nice lol
RosadoRacing
Forgot to mention I went back to the Dyno and it was six degrees to retarded so the car will def pick up alot I felt alot of lag in second n third gear which is why the mph doesn't match the et
jaysol92
Post by jaysol92 »
Good now it should pull more aggressively . low 10s , maybe even break 9s lol
neverlift
Post by neverlift »
yeah 6 degrees is a bunch of timing, might not crack 9's but I think you will be close.
6* global or just at boost?
RosadoRacing
6* overall my timing light was screwed up idk what s13s run with 650whp but pulling 1.4s should get me a 9 sec slip
neverlift
Post by neverlift »
global yeah you might just pull that nine, hit the track man!!!! :D
RosadoRacing
July 19 I'll be at Atco raceway for pan America I think they canceled summer Slam at e town drag racing isn't what it once was. before the years over im a change the wg spring and run 30+psi
Post by adamky »
Very nice launch. That thing hooks.
RosadoRacing
Thanks adamky and to answer your YouTube question the tires are Mt et slicks 26x8.5
