Ka24de extreme revs?
jaysol92
Post by jaysol92 »
Whats the highest you guys have seen a ka rev?? just curious to see what you guys have seen lol
drunknmunky
Post by drunknmunky »
200 r p m
jaysol92
Post by jaysol92 »
200 is superrrrrr high . I don't believe you !
RosadoRacing
Post by RosadoRacing »
I revved mine to 7800 I seen 8500 on the site and import dps Told me 9500.I believe Ventura also said.95
boker240
Post by boker240 »
ive seen 7450 on my afc before but that was hitting rev limiter for 3 sec.jwt raised my rev limit as that's w they do but rods don't like that.
currently n/a.
Freise
Post by Freise »
There used to be an article on old Nissan sponsored Baja cars that used an extremely modified KA, carbed, ran 200+HP NA and revved to like 9k, but it seems I can no longer find the article with the details.
95 240sx KA24DE-T
S15 Injectors
Z32 blow through
jaysol92
Post by jaysol92 »
9500 is impressive for our motors wow
Marcus
Wearer of Missing G-Strings!
Post by Marcus »
The counterweighted crank is the largest obstacle, beyond the rod length.
RosadoRacing
our rods are great there longer than sr20 the crank is the issue but with a ati super damper people rev to 8500
jaysol92
Post by jaysol92 »
so the crank is what starts to get dangerous at high revs in stock trim?
RosadoRacing
yes but there is no need to rev a ka so high ive ran 10.9 on 20lbs shifting at 6500 where as itll take a sr20 or b18 8000 rpm to make similar power. a b18 wont start making serious power till about 6k a ka will make the same power at 4500 with alot more torque
jaysol92
Post by jaysol92 »
Oh wow 6500? Does your power fall off after that ? Or was that by choice ?
Berserker
Post by Berserker »
I tried revving to 6.5k stock cams 50 trim turbo at the track.
Once I reved it to 7k gained 4-6 mph trap speed and better 1/4 mile time
Post by sdaigle240 »
i spend hours on limiter lol. for events, i like 7200, helps me sleep at night. for the street 7500. all depends what you wanna do. for a drift car, a few hundred RPMs can be hugely helpful. ive tried 6800 and it def hinders things.
i got respect for rosado, but id certainly love to see some literature supporting the limits of the ATI damper. if I could conceviably rev to 7800-8000 comfortably with just springs and cams, i could justify the purchase.
240-kid
Post by 240-kid »
It's not the Top end that needs the Help, it's the Bottom.
Gatta keep it from eating bearings and stretching.
I'm sure 7800 would be fine with Lighter Pistons and Rods, FULL bottom End balance (I would include the Flywheel Also), Loose end of Bearing Clearance, Quality ATLEAST 40wt Oil (i.e. 10w40 or 15w40) and some ARP Hardware to keep everything together.
Pistons: 375g
Wrist Pins: 110g
Rods w/ Bolts: 760g
Lightest Low Comp Pistons I've seen are the Arias 89mm @ 353g, Wrist Pin is 105.
Lightest Rods I've seen are the AMS/BC Sportsman @ 605g.
Total that removed ~ .4lbs so just under half a pound. Doesn't seem like much but when you do the calculations for rotating Mass it adds up quickly.
I don't see why you couldn't turn 7800 at that point as long as it's balanced and have some kind of Crank Damper.
Those Baja Motor's that were mentioned earlier still use a Factory Half-Countered crank. It's just modified with the Crank Pulley Bolt Drilled past/into the #1 Journal instead of just stopping past the Snout/Nose. I'm sure the crank has more mods but I can't recall them. But I do know they still used the Half-Countered OEM crank.
RosadoRacing
it was by choice just to get use to the car next weekend I'm racing and put my shift light to 7k. on the dyno we revved it to 7800 and it never fell off kept climbing. but like i said no need to go so high when we make double the power down low than 1.8 2.0 motors and make the same power 2000rpm sooner. top fuels only rev to about 8k and there the most powerful motors in the 1/4 mile
jaysol92
Post by jaysol92 »
you have a point rosado those top fuel drag MACHINES are no joke. You should definately ride that power out if it holds strong, our motors impress me more and more everyday :)
well yeah beyond the springs, the heads in the clear. random good news, arias actually went lighter. Ver 1 is 351-353g, the new ones are 333g. i got the oldies. in percision terms my hy would be a 5658, its not holding powa up top like that 6262 thats fo sho, prob not even worth my time to pursue higher revs.
240-kid
Post by 240-kid »
Arias v2's are lighter? Me like :) Now are they still 2816?
Post by schmauster920 »
Top fuel is hugely limited by rules and regulations, not a good thing to compare to since they are doing all they can within the rule book which governs everything
Piston speed is scary high at redline due to the long rods/stroke, this has a negative effect on bearings.
I have a big T4 that hits around 4k. I feel like shifting around 6500-7k works well enough, but its nice to see people reving the crap out of them
smbonn2005
Post by smbonn2005 »
IIRC It was the CORE offroad series that used the KA motor and if my memory serves me they DID NOT rev to 9k, but only to 7300 due to the harmonics in the crank and having bearing issues..
More RPM's would be of the best benefit to larger turbo guys to keep them in boost longer.
I'm in the middle of trying to get a KA to 9k myself though, but it will not be with the factory crankshaft. Due to the HCW issue it is more reliable in my mind to get a FCW and probably add an ATI dampner onto that as well.
