oil light came on this morning
cham
Post by cham »
I got oil so where do I start? I'll probably replace psi switch,sending unit and pump. But the thing is, no local store carries the pump or sendind unit. So where's the best place to get these parts? Or should I just let a shop check over everthing first?
cham
Re: oil light came on this morning
Post by cham »
oil sending unit/ pressure sensor...same thing.Im gonna try this first
Grant
Post by Grant »
cham wrote:I got oil so where do I start? I'll probably replace psi switch,sending unit and pump. But the thing is, no local store carries the pump or sendind unit. So where's the best place to get these parts? Or should I just let a shop check over everthing first?
9/10 it will be your oil sending unit
