Head swap ? Sohc 2 Dohc
Humke95
Post by Humke95 »
Ok I got a steal on a mint low mile no rust second owner 90 s13. But it's sohc I live in mn so there isn't to many junk yards around with ka dohc, I can find heads tho . So I was wondering if its possible to throw a dohc on my single if the block is diff ect. Thanks
Post by airman »
It might bolt up, but the front covers are too different to consolidate to do a Frankenstein DOHC/SOHC block/head assembly.
Heads definitely have to match! I'm sure someone could pull it off one day, but it definitely wouldn't be easy.
Two-Tone
Re: Head swap ? Sohc 2 Dohc
Post by Two-Tone »
Don't do it. Far too many complications starting off from basic timing. It's just not a thing to do. If it was easy you would hear about it and see it more. If you dig deep enough through a Google search you'll discover somebody who tried it and had issues and also advised not to do it.
drunknmunky
Post by drunknmunky »
There are a lot of guys down in Australia that have done this without said issues.
Grant
Post by Grant »
this can be done, i don't recommend you do it. buy a motor build it for boost
toky042
Post by toky042 »
too much work for lil gain
arob987
Post by arob987 »
Real question is what's your power goals cause there are some mean sohc Ka-t boost that.I swapped to dohc back when there was like no support for it.
Rich260z
Post by Rich260z »
Wait for a deal to pop up. I'm sure you'll find a complete motor, you just need to be patient.
We race from 120mph rolls...
Le mieux est l'ennemi du bien
Grant
Post by Grant »
toky042 wrote:too much work for lil gain
couldnt have said it better myself
Post by sdaigle240 »
drunknmunky wrote:There are a lot of guys down in Australia that have done this without said issues.
RB30 conversion is heavily documented and its still not straight forward at all. theres one in my shop.
drunknmunky
Getting a DOHC would be a much, much cheaper alternative with less hassle.
There is 100% upside.
