How to *properly* run AN fittings with stock fuel lines
Nice find Chris. Use a legit tube cutter and there will be no flaring necessary, right?
Correct. There's a small piece inside the two halves that essentially flares and seals the stock line as you tighten it. I just noticed these are only rated up to 50psi though, not sure how much a regular 37° flare fitting is rated to but you might run into issues if you run over 4 bar fuel pressure.airman wrote:Nice find Chris. Use a legit tube cutter and there will be no flaring necessary, right?
Hmm 50psi rating would be pushing it - especially if you're boosting 20+ psi.
Regular flare fittings are the same fittings used in hydraulics - aka 3000+ psi lol. Of course at that point the hose limits that.
Hmm, also the 50 psi rating might be a safety factor of 2 or more. Might still be okay but I would want to verify with the manufacturer. There could be a similar option by another vendor that can handle the pressure comfortably.
Re: How to *properly* run AN fittings with stock fuel lines
awesome write up man thanks alot.
thanks alot, was actually going to do this, great write up.
Great write up very helpful
- ZERTARACING
Will Be doing this when I go KA-T thats for sure. Nice write-up.
Building my S-chassis in my garage, piece by piece.
This makes chase bays kit look sad...
The more I read about the compression/slip on fittings, the more I'm scared of them!
The last thing you want is atomized fuel spraying out in a hot engine bay from a high pressure leak. No thanks. I'll do it the right way and use flared tubing with the tube nut. No way I'm risking my engine bay at just the minimum to save some effort up front!
