hpipro4 S13 KA24DE-T Build
Re: hpipro4 s13 ka-t build
Were did you get the turbo blanket?
my build aint that impressive! lolshift_down wrote:Ahhhh this is legit! One day my setup might be this impressive! Keep it up, I'm learning a lot from this.
bought it off ebay lol had to modify it to fit.signals13 wrote:Were did you get the turbo blanket?
my ID1000 came in! 11mm tops ill be using the aem fuel rail that will need longer spacers to fit.
injector dynamics goodness!
learning how to degree my cams but 1st i need to set my valve lash .008" intake and .010" exhaust according to BC cam card. intake side is pretty much done but exhaust side was no were near specs. i had to buy a few shims in the 2mm+ range but few needed 1.91mm & 1.93mm and the thinnest nissan carry are 1.96mm.....what to do???
Legit build! Dont forget you can always get a machine shop to machine the shims down slightly.. might be the easiest and cheapest considering how much the shims are
thanksschmauster920 wrote:Legit build! Dont forget you can always get a machine shop to machine the shims down slightly.. might be the easiest and cheapest considering how much the shims are
i just realized i can grind down the top of the valve stems slightly bit and go frm there. not sure why i didnt think about it before i bought 6 shims frm the dealer. oh well.....
Damn dude you do some good work man.. love your attention to detail!! Keep it up youll be building nice **** for years to come
I really like how clean and professional this build has gone.
You've made your project worth more and a piece of art that all of us can appreciate and I thank you for sharing it with us.
thanks you fellas
subscribed, man this is one hell of a build, clean legit
Thanks for the inspiration and great job on the build.
The value of life can be measured by how many times your soul has been deeply stirred - S. Honda
awesome job on the build man, looks amazing.
- superDorifto
wow, this is a fantastic build.
We have a ton of parts in common, and I'm real jealous how good it looks on your build. Im red, nickle, and gold - youre black, golf and silver....looks real good.
thanks! yes very much indeed.superDorifto wrote:wow, this is a fantastic build.
What was mix in the chemical bath to plate them?
i use thiswtfarpus wrote:What was mix in the chemical bath to plate them?
http://www.caswellplating.com/electropl ... 5-gal.html
thanks man
- superDorifto
Same place that I got my nickle plating kit from...super easy to deal with.hpipro4 wrote:i use thiswtfarpus wrote:What was mix in the chemical bath to plate them?
not much update but finally done with valve adjustment. ordered few shims frm my local nissan dealer and took at least a week to get 6 shims. then i needed more for the exhaust side so i ordered some frm nissanparts.cc actually got them quicker than my local dealer considering their in Washington.
anyways.....decided to give this shim tool i bought frm egay!supposedly its for toyotas. at 1st, i was like...damn! this thing works awesome. till i took out the cams out and noticed it was scratching the journals. polished em with 2k sandpaper hopefully it'll be fine!
i was stuck how to switch shims around quicker and not scratching the journals. so i decided to fabbed my own bucket/spring pushed-down out of 304 stainless steel flat bar.
it bolts on to one of the cam cap bolt and pretty much press down on the edge of the bucket and shims pops off easily.
valve lash all done. 008" intake and .010" exhaust.
degreed the bc264 cams. i had to advance intake 2.5degrees and retard exhaust 2.5degrees to come close to bc cam card.
i see why BC recommend valve lash to be .008" int n .010" exh, with stock setting on cam jwt cam gear, specs are almost within the cam card.
- picsbypenny
Can I send you my nuts and bolts to yellow chromate
ya for a price!picsbypenny wrote:Can I send you my nuts and bolts to yellow chromate
WOW that's an AWSOME build
PM me what kind of pricing it be to get some nuts and bolts yellow chromated
- picsbypenny
i got a pm from you but it said deleted by user :/
How much did those ARP exhaust manifold studs cost you? Link please?
hmmm...i dunno what it was....picsbypenny wrote:i got a pm from you but it said deleted by user :/
their not arp! their oem but i electroplated em then dipped in black chromate.mewantkouki wrote:How much did those ARP exhaust manifold studs cost you? Link please?
can you show us how to do the electroplating? or reference a source?
I've seen it done on youtube but I'd like to ask how you do it.
- picsbypenny
I asked for price on every external bolt yellow chromatehpipro4 wrote:hmmm...i dunno what it was....picsbypenny wrote:i got a pm from you but it said deleted by user :/
