finally building my ka :-)
signals13
Post by signals13 »
So I finally got my motor back with all my goodies and will be taking pics along with the build stay tuned.
S14wayz
Re: finally building my ka :-)
Post by S14wayz »
whats the plans?
My S14 Build Thread
viewtopic.php?f=40&t=59534
signals13
Post by signals13 »
Ok so here are some pics of my motor I finally got back from the machine shop along with the head.
Thanks to turboholic for the cams which will be in asap just waiting for my cosworth hg.
JE pistons and K1 rods
Head is stock except for the cams, thinking about at least port matching intake and exhaust ports.
Decided to paint block white its high temp.
And should end up looking like this :)
Post by shift_down »
The white looks clean! What color is your bay going to be?
foltzs14
Post by foltzs14 »
Did you have a local machine shop do the work? The setup looks fantastic thus far.
The value of life can be measured by how many times your soul has been deeply stirred - S. Honda
arob987
Post by arob987 »
Looks good keep up the good work
signals13
Post by signals13 »
[quote="shift_down"]The white looks clean! What color is your bay going to be?[/quote]
As of now its black not sure if I should change it, but I am thinking about a wire tuck.
signals13
Post by signals13 »
[quote="foltzs14"]Did you have a local machine shop do the work? The setup looks fantastic thus far.[/quote]
Yea jacks machine shop (its under a different name now but they still have the same phone number) did everything apart from assembly, i'm assembling it, thanks.
signals13
Post by signals13 »
Thanks guys I still have a long way to go :-)
signals13
Post by signals13 »
So I received my HG :D
Next step is head install and cams, assemble complete motor. I'm still debating whether or not to port match intake and exhaust ports??
signals13
Post by signals13 »
So head is torqued down lower timing chain is on upper is half-way on just need to get the dang intake cam sprocket off and I can put the timing covers on :)
oh and cams are on and torqued.
NateDogg
Post by NateDogg »
Nice did you get the 1.1mm hg?
'91 S13
Built, balanced KA-T
signals13
Post by signals13 »
I have the 1.5mm.
NateDogg
Post by NateDogg »
Do you know the cr change on that?
'91 S13
signals13
Post by signals13 »
I should be right around 9:0, .025 was removed from head, with 8:5 pistons.
S14wayz
Post by S14wayz »
signals13 wrote:I should be right around 9:0, .025 was removed from head, with 8:5 pistons.
What made you go with the 1.5 instead of 1.1?? Curious cause I was about to order one last night and realized there were different thickness's and had me at a loss. And im assuming the thickness will play a pretty big part in c/r.
My S14 Build Thread
signals13
Post by signals13 »
Yea it will affect the compression ratio, but it was because of the amount of material removed from the head and block.
signals13
Post by signals13 »
Update: 9/2/13
I received a bunch of parts that where ordered still waiting on more but its all going steady cant wait to finish her up sooooo excited :)
Oil feed setup
power steering on and water feed ready
Cleaned my engine bay and transmission the best I could with an electric pressure washer
Before:
After:
I love how clean the power steering rack came out just need to get the car on a lift to pressure wash underneath, oh I also installed Energy Suspension power steering rack bushings :) thanks for watching guys.
drifting1two40
Post by drifting1two40 »
nice build so far cant wait to see it completed
MidwestJeff
Post by MidwestJeff »
That wash made a night and day difference
signals13
Post by signals13 »
Thanks drifting1two40, yea it did want to wash the the underbelly Jeff.
500hpKA240sx
Post by 500hpKA240sx »
looks sick! i really like the block being white. looks awesome
signals13
Post by signals13 »
Got a couple more things just really waiting on clutch ugh..... why must it take soooo lonngggg........
signals13
Post by signals13 »
Had an issue with previous clutch ordered thru cimotorsports.com, just wanna say I will not be doing business with them anymore. Clutch ordered thru ebay and its here=)
Water return line to t-fitting.
Just need to do the ceramic coating on mani and can throw motor in, soooo excited :D
t66-240
Post by t66-240 »
The oil feed is too long. The vibration in the KA will eventually crack it.
FWIW,
Mike
97 Altima (stock)
05 350Z touring powerlab turbo
93 240SX coupe not so stock
543.26 rwhp 463.88 rwtq
Mike Lee
signals13
Post by signals13 »
Are you talking about the t-fitting? Or the stainless line? What should I do?
t66-240
Post by t66-240 »
the whole thing is too long(not the line) and it will eventually crack. I did the same thing back in 97 when I first turboed my KA. I ended up removing the plug on the oil filter housing and re-tapped it for the turbo feed.
97 Altima (stock)
Mike Lee
signals13
Post by signals13 »
Thanks for the heads up I'll definitely change that around. :)
Crash33
Post by Crash33 »
If you want to keep the oil pressure switch, look into a Honda oil feed adapter. I have been using one for years and it is a much bigger piece that resists cracking. plus if you have to go back to na you can just plug off the turbo feed port.
1993 240sx fastback FINALLY TURBOED!!!!
T3\60-1
JGS LOG MANI
740CC INJ.
NISTUNE
signals13
Post by signals13 »
Hey crash33 could you send me a pic of what you're setup looks like? thanks.
Update so here is my oil drain plug ready now :)
