Rebuild my KA with stock internals or wait and build it?
So I have a ka which I bought with a trubo kit on, about a week after the car blew a timing chain guide and I disassembled the motor because I saw the car was over boosting (about 13-14 psi on stock pistons) and I thought it was rod knock, then when I get into the engine there isnt anything off, pistons look really worn out, but nothing other than that. Should I rebuild my KA cheap, then have the crank grinded, the cylinders measured and possibly bored and honed, then rebuild the engine off some ebay kit that I can pick up for cheap with pistons. anyways what would you do ?
tl:dr my car blew up, I have no idea why. trying to rebuild on stock internals (so I can drive the damn thing soon) or should I just wait to put forged pistons and rods ? just tryin to drift hahah
Thank you so much guiesss
here are my stuggles http://www.youtube.com/watch?v=hzj9YDVUWz0
PLEASE HELP
PLEASE HELP
Re: Rebuild my KA with stock internals or wait and build it?
I tried looking all over, are there any good rebuild kits or do I need to part everything together myself
I think what I might be able to do is rebuild it using the same cast pistons and run it until it blows again? but would I have to hone the cylinders to rebuild it ?
it will depend on how soon you wanna do this again, don't be too cheap..
if your in a rush look for a good used running motor run that while you build a forged motor on the side good luck.
Oh believe me I know, im about to just rebuild it with the same internals, cross fingers and hope everything goes right, there is a drift event this weekend I really want to make it toosignals13 wrote:if your in a rush look for a good used running motor run that while you build a forged motor on the side good luck.
I would say you should wait and build it up! time is sensitive though, obviously.
What turbo are you going to run and how much power do you want to make out of it? If it's nothing too crazy, a stock rebuild will suffice.
- Alonso
Build whatever tf you want. Its really going to depend on you and your goals/budget.
I built a stock bottom with a built head(bc 272 cams, titanium retainers yada yada) running billet 6765 divided t4 turbo, dual 44 wgs etc etc. Basically everything for 800hp, only aiming for 450hp while a forged bottom end is assembled.
I'm not scared to push the stock bottom end, and I'm just trying to have fun!
AWS D17.1 certified
AWS D17.1 certified
David48 wrote:What turbo are you going to run and how much power do you want to make out of it? If it's nothing too crazy, a stock rebuild will suffice.
Im running a t28 with the goals around 300hp.
also my cylinder walls have some rust marks in them. http://imgur.com/tJ23FON,CxXqw0Z do I need a bore, or can I get away with honeing it myself with my harbor freight tool ?
Stock internals are good to about 300 or so HP.
Just change the head studs and use ARPs, and make sure your tune is GOOD or kaboom.
Go bottom mount t2 manifold and turbo and that's enough.
People tend to go crazy for top mount setups, for the numbers, like I did, but I hated the damn lag.
I'm on bottom mount manifold with GTX turbo and it's fun fun fun.
Im on a built motor with Felpro HG and All is good!
Just build wouldn't rebuild a stock KA
Gtx turbo are fun
Gtx turbo are fun
