10.59 @ 140mph
10.59 @ 140mph
23lbs of boost shifting at 7000 using nlts 11.4 afr it was a great fun pass. http://imageshack.us/a/img18/9573/71m3.jpg
Re: 10.59 @ 140mph
That car never fails to make me happy, nice job bro.
Re: 10.59 @ 140mph
thank you
Re: 10.59 @ 140mph
Good job.
Re: 10.59 @ 140mph
thanks. Here's a recent pic I took of the new turbo. http://imageshack.us/a/img5/7075/tfnq.jpg.
Re: 10.59 @ 140mph
borg warner?
Re: 10.59 @ 140mph
Yeah s366 .88ar going to get the billet wheel for next year
Re: 10.59 @ 140mph
Nice. Keep it up.
Re: 10.59 @ 140mph
thanks I have a few things I need to work on such as lag n the car being hard to control past 130mph
Re: 10.59 @ 140mph
What happened to the PTE turbo you had on the car?
Re: 10.59 @ 140mph
viewtopic.php?f=2&t=60127&p=511681#p511681ALTKAT96 wrote:What happened to the PTE turbo you had on the car?
Re: 10.59 @ 140mph
thanks supa. yeah the oil pump broke and bent the shaft on the pte. the bg shaft is alot larger and seems to be built better so far I'm enjoying the bg alot more than the pte.
Re: 10.59 @ 140mph
Nice pass
Re: 10.59 @ 140mph
how much did it weigh? also what mods do you have internally?
Re: 10.59 @ 140mph
without me 2650 lbs. arias .020, eagle rods, stock crack, stock damper, supertech springs n valves, crower v3 cams stock position, arp stock studs, clevite stock bearings. pretty simple straight forward build with low boost ka's are a hell of a motor that can withstand abuse like none other
Re: 10.59 @ 140mph
Nice pass!! What's your tire/suspension setup?
1995 S14 KA-T "Trucky"
11.2@136 mph
Youtube Channel:
https://www.youtube.com/channel/UCpxu7V ... subscriber
11.2@136 mph
Youtube Channel:
Re: 10.59 @ 140mph
26x8.5 slicks. Kyb agx shocks sportline springs, z32 lsd stock bushings and arms
Re: 10.59 @ 140mph
How much power are you making?
Re: 10.59 @ 140mph
This run was 580whp couldn't turn the boost up cuz it would spin the tires in all four gears!
