I'm posting a build thread because I want to be held accountable for my actions and get feedback on my setup and show other people that it's not always hard it just takes time, patience and money!
Auto DD -
Stock rebuild:
clevit bearings, felpro full gasket kit, reconditioned head, OSK timing, New gates WP , aftermarket oil pump, Standard rings and emmisions removed intake including EGR and PCV. Tig welded locally.
Reason for rebuild:
valve seals were leaking causing the engine to smoke and when I took the engine apart I noticed one of my bearings had a chunk missing out of it and was using oil to compensate for lost material.
Manual DD/Track
Performance rebuild:
Clevit bearings, felpro full gasket kit, Brian Crower Stage 3 cams with springs/ clearanced head, OSK timing, New WP, OEM nissan Oil pump, Wiseco .40 over forged, ARP main rod and head studs, Eagle rods, Xcessive intake manifold with IACV plate and stud kit, Xcessive oil pan adapter and ISIS Sr20 sump, ATI Crank, magnecore wires.
Turbo:
Greddy manifold, TD06-20G and greddy downpipe.
Reason for rebuild:
Generic cheap timing chain kit had a plastic piece break at the track and clog my oil sump tube and drop my oil pressure to bring the your engine is F****** light on. The engine was a stock rebuild at that time purchased from Japanese import spec out of Texas.
Joedirte's S14 KA/t builds
Re: Joedirte's S14 KA/t builds
This is the stock rebuild for my DD. Easy stuff here folks
Cylinder hone complete
Block cleaned
Taped and primed
New OEM freeze plugs and fresh VHT engine paint
Cleaned and painted oil pan
I tried to get most of my bolts/anything zinc from factory re platted for corrosion protection and overall good looks. It's not bad on price if you can find someone locally to do it
Complete engine ready to drop in!- S14wayz
clean rebuild, I'm doing the same right now so I got a DD while I build up the other block for the summer. HATE the bus lol
Thanks man. lol I would tooS14wayz wrote:clean rebuild, I'm doing the same right now so I got a DD while I build up the other block for the summer. HATE the bus lol
Onto the track car build Fresh .40 over with Wisecos and Eagles Decked Block Freshly zinced How long will this look pretty? Sumpthin' is up
Tasty looking builds. Keep us updated
- S14wayz
must have taken you ages to polish all those parts. woohhee I gave up 3/4 the way through polishing my stock intake manifold lol
no updates?
- street_240sx
supersayianjim wrote:no updates?
4 years later......
03 evo8 gsr: stroker 2.3
Any update on this build?
