Ka-t what fuel set up do i need?
I bought used injectors for my ka-t build already have build bottom end and head. The injectors are 1000cc and i am aiming for about 400hp. Are the injectors sufficient and what size fuel pump? Thank you for the help.
- hotbox240
Re: Ka-t what fuel set up do i need?
With a walbro 255 you should have more then enough fuel for 450 whp.
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
What fuel? If 93 your good. You should get a bigger pump for future expansion. The 400lph wally is nice.
thanks guys. appreciate the advice
- jessicabrown
A high-quality estimator of volume to power is something like 10 hp per gallon or 2.64 hp per liter. It is becoming more and more common for people to use an in-tank electric pump to feed a carbureted engine.
