seth's zenki build
seth's zenki build
I plan to redo the interior, suspension, paint, and turbo the motor (w/ forged pistons, rods, and some top end work).
Here is the current interior.
There are a few issues lol. Tons of mouse **** all throughout the car and then there's this...
It's got white and black spray paint poorly applied to some of the interior pieces. I'm gonna do all the whole interior in black with grey or maybe silver accents. I'm currently testing out colors and textures on the plastic trim pieces.
Here's what a lot of the interior is looking like:
After primer, black base coat, metallic silver, and clear. I'm trying to learn how to paint half way decent before I do the entire interior. I'm thinking of doing the radio/ hvac controls and the shifter trim in this color. And maybe other little pieces, like the plastic around the vents in the doors. I'm worried that it's going to look ricey though.
Bought a blown s13 ka24de for its manual tranny for $200. Not sure if I got a good deal or not. It did come with a brand new starter, a complete a/c system, and all accessories, so I'll have some spare parts. I still need an s14 speed sensor and a driveshaft though.
Re: seth's zenki build
I let my pile of parts grow before I began putting it all back together. It's all in the picture minus the J30 VLSD and HY35.
Parts shown:
Precision PW-39 wastegate
HKS SSQV4 BOV
MSPNP ECU
Ricer exhaust
CXRacing intercooler kit
Clevite main and rod bearings
Eagle rods with ARP2000 bolts
OEM clutch pedal assembly
Injector Dynamics 1000cc injectors
AEM fuel rail
AEM 320 LPH fuel pump
Autometer mechanical boost/ vacuum gauge
Innovate MXT-L wideband
Evergreen complete gasket set
Cometic head gasket
ARP head studs
Clutch master cylinder
Clutch slave cylinder
Water pump
Parts shown:
HKS SSQV4 BOV
MSPNP ECU
Ricer exhaust
AEM fuel rail
Cometic head gasket
ARP head studs
Water pump
The machine shop told me I would be alright with a .020 over bore so I ordered the 9:1 wisecos, got the block back from the shop and 3/4 pistons and rods installed. The fourth piston had a mismanufactured ring which snapped in half. Wiseco sent me out a new set of rings and I'll get them in in the next couple of days. I went with a 0.017 gap on the top ring and 0.019 on the second ring. Does that sounds right? And I have the crank girdle in with the factory bolts, but I decided to go with ARP's and have switched them out.
Got the last piston in.
And the lower timing chain.
And the head on.
I accidentally stripped out the threads for the upper timing chain pulley. The factory bolt only goes 1/3 of an inch or so into the threads but the hole itself is about an inch or so deep. I've looked everywhere for an m12 x 1.25 x 110 bolt to replace the factory 100mm bolt but 100mm is the longest I can find anywhere. I didn't want to fix the threads with a helicoil bc the problem is not enough thread engagement and without a longer bolt that same problem still exists. So I kept looking and eventually found a 120mm replacement bolt at a local shop that is known to be the best place for metric fasteners, and cut it down just enough to fit. I also soda blasted the front cover while I had it off.
And the head on.
I also welded a bung in the oil pan for a return from the turbo:
Installed the Competition Clutch White Bunny clutch and flywheel kit:
Installed the transmission:
Dropped the motor in:
Fabricated a new downpipe:
And installed the J30 differential and one-piece driveshaft, and gathered some more finishing pieces.
I'm working on getting the coolant and vacuum lines finished now.
YES. megasquirt is awesome!! I also like the color for the trim pieces, looks very professional. keep up the good work!
- S14wayz
Looking good! Yeah good choice with mspnp2
I got the fuel pump installed last night. I went with an AEM 320 LPH in take fuel pump.
Here it is next to the stock fuel pump.
This is the flow sheet it came with:
The pump was featured in a "fuel pump shootout"
http://www.importtuner.com/tech/1405_fu ... ewall.html
The included fuel sock wouldn't work in this application, and the stock fuel sock wouldn't fit on the AEM pump, so I used the AEM's fuel sock fitting with the stock fuel sock.
I had to cut the hard tube off the end of the stock sock, cut off the fitting from the AEM sock, and weld the two pieces together.
Done.
Done.
- shift_down
Everything looks great! I love how you wrote "ricer exhaust" I lold hardcore.
Thanks shift_down. And I was just being honest about the exhaust lol.
I got some wiring done today.
Does anyone know what this middle wire goes to? It is in the same bundle of wires as the wire that goes on the positive terminal of the battery, but about a foot before the battery that wire branches off. And does that red connector go to the positive terminal of the battery as well?
I thought one goes to the starter and other other to the main fuse panel.
Cosmetic Head Gasket
Eagle Rods
Stock flywheel
Spec Stage 3+ Clutch
ARP'ed Everything
Clevite Bearings
SARD 850cc Injectors
Eagle Rods
Stock flywheel
ARP'ed Everything
Clevite Bearings
The middle connector is possibly the starter lead? [Edited so no misinformation is spread]
The red connector fits the positive battery cable perfectly, I think I have that part right.
I finished the gauge wiring:
It took all day, it was well over 100 feet of wiring.
- BigLoukaT
That is one cable I would recommend you be absolutely sure of.614s14 wrote:I think you're thinking of a different wire that goes to the ground. There is a spot on the intake manifold that fits that ring terminal perfectly so I'm pretty sure that's where it goes. I could be wrong though (I hope not). The red connector fits the positive battery cable perfectly. I think I have all that right..
The intake manifold ground (if similar to my sohc) is relatively straight through from negative battery terminal to body ground to intake manifold. It does not go through the lower engine/trans harness. It is hard to tell from your picture... it looks like its originating from the lower trans harness?
I agree that looks like the starter lead. To be sure:
Take a multimeter and check for continuity between the positive terminal connector and the ring terminal you show. If it is indeed the manifold ground, there will be no continuity.
Thank for the help. I'll check that out before I do any more work on the car.
After looking at the wires and tracing them throughout the harness, I don't think that cable with the 90 degree ring terminal is the starter lead. The other end of that cable is attached to the alternator, and the ring terminal end shown in the picture is supposed to bolt to fuse box where the battery ground cable is bolted, I think. Does that sound right?
And for the auto to manual transmission wiring, do I need to do anything other than jumper the top transmission connector on the fusebox, and run the green and black wires from the third connector down to the reverse switch on the transmission? The threads I've read about doing the wiring say that I need to wire the neutral switch from the transmission to the ECU, but I can't think of why I would need to do that, and I don't want to mess with the ECU wiring if I don't have to.
Update: (my last post posted twice so I deleted one of the posts and now they're both gone)
I got the car running with the base tune that the ecu came with, then allowed VEAL to make changes as I went through the rpms. It was idling and running well (sort of), but after turning the car off and back on again, it wouldn't start. I had to hold the throttle all the way open just to get it to idle, and it ran really rich. I went through this the first time I started it with the MSPNP2, but I attributed the problems to something other than the tune, made some adjustments to the car, and reloaded the base tune (and changed my injector and wideband settings). The car started up fine with the base tune, so I imagine if I loaded the base tune again, it'd start up fine. It wasn't until i used VEAL to make adjustments that I had the starting/running issues.
What am I doing wrong?
Quick update: Got the car running again, and with the help of SupaKat's megasquirt thread (and his supakat.msq file) I was able to get it running pretty well. Also got my ricer exhaust installed, cleaned up the engine bay a little bit, relocated the battery to the trunk, and installed a vacuum block to clean up the lines a bit. I didn't take any pics except for the exhaust. My downpipe doesn't mate with the midpipe all that well so I've ordered new piping and I'm just going to make a whole new downpipe. Here's the 2 fast 2 furious exhaust:
Help! What is this sound?
It sounds like rod knock or something, but the bearings are all new, I really don't think that's what it is. I'm thinking it's the timing chain or the cam timing is off and the valves are hitting the pistons.
https://www.youtube.com/watch?v=xQeGHjX ... e=youtu.be
Down pipe parts!
Keep up the good work man and keep us posted.
<< Yuh dun know!!
I made a v-band adapter so that I don't always have to unbolt all five(very hard to get to) bolts:
Coming together:
Complete:
I know the welds look horrendous but they're structurally sound. I may have a stainless downpipe made by someone with skills at some point but this will do for now. It'll be wrapped anyway and you won't be able to see much of it.
Coming together:
Complete:
I pulled the top timing cover and this is a picture of my cams at cylinder #1 TDC on the compression stroke:
I believe I was a tooth off and fixed it. I made sure to turn the motor several times by hand to ensure that the valves weren't hitting the pistons. We'll see what difference it makes when I start it up again.
I also found that the top bolt of the right side lower chain guide was loose and I could wiggle the whole guide. That's probably where that noise was coming from. I tightened the bolt and I couldn't move the guide anymore but I'm thinking the bottom bolt has got to be loose as well.
*Edit: not sure why I originally said half tooth
i think you are jumping to conclusion on timing. the cam gears are suppose to have 6 solid links between the center links of each the cam gears. that picture looks correct currently. dont worry about actual location just work about link count on chain motors. location is more of a belt issue.
The link count only works when the intake cam is positioned correctly. Make sure the lobes are facing out. Look at the FSM to get actual specs.slideland240 wrote:i think you are jumping to conclusion on timing. the cam gears are suppose to have 6 solid links between the center links of each the cam gears. that picture looks correct currently. dont worry about actual location just work about link count on chain motors. location is more of a belt issue.
https://www.youtube.com/watch?v=jbaFoxm-5lE
Think of it this way:slideland240 wrote:i think you are jumping to conclusion on timing. the cam gears are suppose to have 6 solid links between the center links of each the cam gears. that picture looks correct currently. dont worry about actual location just work about link count on chain motors. location is more of a belt issue.
If the crank stays in the same place and I rotate both cams 3 teeth, the marks on the cams will still be the same number of links away from each other, but that doesn't mean that the cams are in the correct place. You're right about the dots on the cam gears needing to be 6 links away from each other, but they also need to be in the correct placement relative to the crankshaft.
Downpipe and v-band adapter are complete. I put a new copper gasket between the turbo and the v-band adapter so hopefully I never have to mess with those bolts again. Worst case scenario I can now just pop the downpipe off the turbo and unbolt the turbo from the manifold to get to all those bolts.
Starting to look like a working vehicle
So I got the car up and running, it starts, idles, drives around fine, and below 10 psi it runs great. Right around 10 psi it starts to break up real bad. Could this be spark blow out? Attached are some megasquirt datalogs. How does this look?
- Attachments
- 2015-04-19_15.12.35.msl
- long datalog
- (18.71 MiB) Downloaded 177 times
- number1.msl
- shorter datalog
- (8.21 MiB) Downloaded 172 times
In your log, MAP at 181.2 kPa (11.5 psi) shows 10.2 AFR with 17.5* of timing. Afr's are a little rich and you could close gap down a bit. Do you have boost cut turned on? Please do if you have not done so. My tune goes up to 30psi but I have boost cut set for 32psi. Another section of the log, you hit 184.1 kPa @ 16.8* which is good but AFR's are 9.8. Gap plugs smaller, clean up AFR's to 11.0 in boost and you should be able to make a full clean rpm sweep.
Thanks a lot. I'm not sure if I lowered the boost cut from what your tune is set to or not, I'll definitely look at that. Right now I'm just running a 15 lb wastegate spring, no boost controller. I've got the injector size setting at 800 cc/min, and I'm doing some research to figure out if it would be better to increase the injector size setting to lean out the top of the map (and fine tune from there) and then increasing the ve numbers at the lower end of the table, or to just leave the injector size at 800 and pull fuel from the top end. I read somewhere that ideally you would go as low as possible with the injector size setting to take advantage of the full resolution of the ve table. As in you could tune all the ve values from 0-250 (or whatever the max ve value is), rather than only having the range of 0-200 or 0-175 or whatever you're highest ve cell is at. Thoughts?
Base pulse width is lower the higher you go with injector size right, or do I have all of that backwards?
What are your plugs gapped at now? Try going to .025 on BKR7E. You haven't even opened the wastegate fully yet!
Regarding the VE table, I have my idle around 37-42. I have enough control over my injectors; full boost at 30psi is around 90. If I plug in 100, she starts to spit fuel out the back uncontrollably. Now, I have not read the megamanual fully, I just dove into the ecu and went ham. There are key fundamentals that the manual layout. Thus is the main reason why I cannot say I know my stuff 100%. I read excerpts on things I want to learn, but I never sat down on the toilet and read from page 1.
FYI: I have my req fuel wrong. If I put 1600cc, I would need big ve values to idle and probably in boost come close to maxxing out the table. I had ve values I set it up like that and did not like it. I always take away 30% of fuel in my calculations cause I am running e85. So my injectors in req fuel should be 1100. I had them there for awhile but when I did my q45 tb, it ran lean as hell. I did not feel like redoing the whole map since it was running good so I just rescaled my injectors to a lower cc I think 700cc so it will increase the pw. I could have just added a percentage to my whole ve map but I did not. Not sure why.
Correct, base pw rises as injector cc goes down and vice versa.
