New beginning
New beginning
Over the last four years, I have been putting together my setup. Began with a cheap turbo setup, but decide to to it right the first time.
ONLY REAL MEN STAY KA
- Forum Moderator
great looking car man .. silvermoss is an awesome color ... keep up the good work .. what is your plan for the motor?
I have so for the is
ARP undercut headstuds
Cometic 90 .060 HG
Felpro gasket set
Coming soon
Wiseco 9.5:1 90mm pistons
Bc or eagle rods
ARP main studs
Unsure of if I want build head, if I do most likely bc cams or crower cams bc springs and valves.
Turbo kit setup I have so far
Ebay manifold most likely to switch
Dsm 1st gen bov
oil lines
turbonetics evolution wastegate
Huge ass fmic
Need
T3/T4 .63 ar
Boost controller
downpipe
Intercooler piping
I have
S-AFC2
Apexi boost gauge
Hks pressure gauge for oil
Hks temp. gauge
greddy turbo timer
Walbro already installed
Need
Efi specialist Ecu
suspension parts
Tanabe springs
Koni shocks
Circuit sports tension rods
god speed sway bars fronts did not fit that well
energy bushing full rear subframe/diff/control arms/sway bar end links
Cometic 90 .060 HG
Felpro gasket set
Coming soon
Bc or eagle rods
ARP main studs
Dsm 1st gen bov
oil lines
Huge ass fmic
Need
T3/T4 .63 ar
Boost controller
downpipe
Intercooler piping
I have
S-AFC2
Apexi boost gauge
Hks temp. gauge
greddy turbo timer
Need
Efi specialist Ecu
suspension parts
Tanabe springs
Koni shocks
The eagle rods can hold 400+ and cost much less. They are the way to go.
Also, I would try to say with .020" overbore on the pistons. most machinists will recommend not to go .040" overbore when doing a boosted ka.
If you plan on turning higher RPMs then build the head, if not, then there's no need.
Just a couple tips. Looks good so far!
- TanManS14
I always wonder about the power capabilities of eagle rods. I honestly think its far more than they say it is. I've never seen them break before. The only forged rod i've ever seen distorted was a crower, i forget what car it was in. But i know the rod bent, and he was still making passes with it, pulled the motor apart for some unrelated reason and realized it was bent lol. Idk, i wouldnt be surprised if you can get 800 out of em.
Re: Finally lowered now on to the motor
So just a sneak peek at what should be done in the next couple months, just got the car back out of storage. Should be interesting to see what it puts down at 20psi.
BW s256rs .75a/r twin scroll
FullRace manifold
Tial wg
Custom intercooler setup
Hks bov
JE pistons
Manley rods
Arp main studs/head studs
New oem oil pump
Timing chain kit
Supertech valves
Supertech valve spring kit
Crower 264 cams
JWT cam gears
Cometic .060 HG
Felpro gaskets
Injector Dynamics 1000cc
Beercan custom fuel rail
Fuel labs FPR
AEM Ems2
AEM uego
AEM boost gauge
AEM Sensors
Super damper
White bunny clutch kit
Koyo radiator
Mishimoto fans
Nismo thermostat
FullRace manifold
Tial wg
Hks bov
JE pistons
Manley rods
New oem oil pump
Timing chain kit
Supertech valves
Crower 264 cams
JWT cam gears
Cometic .060 HG
Felpro gaskets
Fuel labs FPR
AEM Ems2
AEM uego
AEM boost gauge
AEM Sensors
Super damper
Koyo radiator
Mishimoto fans
Nismo thermostat
Re: New beginning
Nice setup. When you get done, hopefully I will be up and running. Let's go hit the track!
- nissanfanatic
Re: New beginning
Which Manley rods did you go with?
Re: New beginning
Car headed to get custom downpipe fabed
- Attachments
- image.jpeg (38.2 KiB) Viewed 15054 times
Re: New beginning
Almost done having issues with the full race manifold with the return ps line.
- Cute240sxGuy
Re: New beginning
What issues are you experiencing? Is the compressor housing hitting the PS line bolt?rtm240sx wrote:Almost done having issues with the full race manifold with the return ps line.
Re: New beginning
Power steering line is hitting the manifold. Tried a AN fitting but since I still have a/c line I can't use it.
Re: New beginning
What was the final numbers?
Re: New beginning
Last year my 97 kouki got rear ended, I need a chassis to swap the motor into. I looked at numerous different options and tried to find another clean kouki but they were way over priced. I already had a R32 GTR so I had lots of stock parts laying around. So I decided to buy a R32 gtst and swap out the RB20 and swap in my fully built KA. This is the process it has made.
Found the R32 GTST on Japanese Classics website decided to buy it, though I will never buy a car from them again.
The car arrived January of last year. The car seemed to be just pieced together which didn’t bother me since I wanted to track the car. Plus the RB20 ran perfect.
I contacted the the guys at Full-lock llc to help me with the swap since I was super busy with work. They pulled the RB20 the first day the R32 showed up and I sold it the next day.
A s13 crossmember was sourced.
Now we are just waiting on the a wire harness from wiring specialties, then I’m taking the car to get retuned. Since the motor was already tuned on a AEM EMS V2 @19psi on 93oct but had cold start issues and the guys at full lock found it had a broken head stud and head gasket that was starting to go which was swapped for brand new arp studs and a cosworth HG.
- nelson240sx
Re: New beginning
That is a sick swap, gorgeous R32 chassis. Its one of my midlife crisis cars : )
Does the R32 bay have more room than the S chassis?
- Alonso
Re: New beginning
LMAO!! HELL NO!!! a while back a did a custom turbo kit in a R32 GT-R and....a s13 definitely has more room between the strut towers than the R chassis. Huge pain trying to stuff everything while keeping AC and PS. You’d think it would be the other way around since the R chassis is larger than our S-chassis...
AWS D17.1 certified
AWS D17.1 certified
- nelson240sx
Re: New beginning
sadness.... would have through there would be more room. Glad to see there are still some old school guys active on the board
