Waste Gate Choice for 500whp +
S14wayz
Post by S14wayz »
So may seem like a stupid question but I'm in the middle of ordering parts mani/turbo/w/g and blow-off and need some help on wastegate size (I searched but no solid info). I'm probably going with a t3 6262 Precision turbo .82 A/R Vband and DOC manifold which offer 38mm flange, MVS and MVR.
So based on that I got to pick between 38 & 44mm and I assume 44mm wastegate should be used for my application but not sure.
Found one post on another forum but not sure how accurate it is.
"Wastegate size for power level...
32mm up to 400hp
38mm up to 500hp
42mm up to 900hp
51mm up to 1400hp"
My S14 Build Thread
viewtopic.php?f=40&t=59534
denty95
Re: Waste Gate Choice for 500whp +
Post by denty95 »
im using a 38mm and im shooting for over 500
96 s14
arias 8.8 pistons, brian crower rods, acl bearings, brian crower stage 2 cams, cx racing front mount turbo manifold, gt35r, 850cc injectors, apexi dual n1, greddy profec-II, xcessive intake, AEM EMS, cometic hg.
wannabethestig
Post by wannabethestig »
I would think the size of the turbo and housing, amount of boost, manifold design, exhaust size and even the boost controller and solenoid would also contribute to the selection.
rn240sx
Post by rn240sx »
S14wayz wrote:"Wastegate size for power level...
32mm up to 400hp
38mm up to 500hp
42mm up to 900hp
51mm up to 1400hp"
Its actually the opposite… The Lower the boost/hp level the larger the wastegate needed … The higher boost/hp level the smaller wastegate needed.. Here is how it works…
When your pushing high boost/ hi hp MOST of that exhaust is being driven thru the turbo and down pipe (hence the hp boost & hi hp) and minimal thru the wastegate so a small wastegate is ok for high hp boost/hp setups… Think about it… high boost/high hp means the turbo is getting MORE of the exhaust gas...
On low boost/ low hp setups, MOST of the exhaust gas will route thru the wastegate and the left over will go to the turbo (hence the low boost/ low hp) … This is when you need a large wastegate to allow the majority of the ex gas to flow thru it smoothly without any restriction…
I can tell you that i have a Tial 35mm wastegate and i have pushed 25 lbs and as little as 7 lbs and it works fine… it may be the smaller of the wastegates that they offer but it was large enough to flow that much ex gas and keep the motor solid at 7 lbs…!!!
And to prove my theory from the above explanation… When i pushed 25 lbs of boost… I NEVER heard that wastegate open up….. !!!!
When i pushed only 7 lbs… that wastegate would open and SCREAM bloody murder… YET hold 7 lbs solid…!!!
Don't let any sales idiot or some wannabe tech on a forum tell you that you need a LARGE wastegate for high boost high hp setups… if they do, they don't know what they are talking about…
ViperGT
Post by ViperGT »
ive got an mv-r on a custom log mani, had a t25 on it and an hx35 now (maxed out because of manifold flow at about 17psi) with the mv-r ive been able to run 4psi of boost on a small spring. most people run more than this but when i was first tuning i was iffy but iit did the job.
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
arp head, main, rod bolts
osk timing
custom downpipe
lol:
Post by beercandrifter »
S14wayz wrote:So may seem like a stupid question but I'm in the middle of ordering parts mani/turbo/w/g and blow-off and need some help on wastegate size (I searched but no solid info). I'm probably going with a t3 6262 Precision turbo .82 A/R Vband and DOC manifold which offer 38mm flange, MVS and MVR.
32mm up to 400hp
38mm up to 500hp
42mm up to 900hp
51mm up to 1400hp"
Most people that run the 500+ range I have seen run the 42mm size
