ka24de/e stock ignition cure/map.
Adrenalin
Post by Adrenalin »
Hey guys, I asked this in sohc kat section but maybe this is a better spot. Does anyone know of or have a stock ignition curve or map for ka24de or ka24e?
Many thanks.
D21 Pickup in the build - Powered by hybrid KA-R
viewtopic.php?f=42&t=60135
Re: ka24de/e stock ignition cure/map.
Post by adamky »
This is a timing map for a S13 KA24DE:
Adrenalin
Post by Adrenalin »
Thanks Adamky, your the man.
This a stock curve or modified?
Cheers.
Post by adamky »
Stock map
Adrenalin
Post by Adrenalin »
Thanks that's great.
Wow, It has a lot more advance down low than I was expecting.
Post by adamky »
Let me double check it but I'm almost positive that's the stock map.
Post by BigLoukaT »
Meant to respond but never got there. I would feel comfortable using the ka24de map as a safe start. The combustion chamber design for the single jingles dictate that we will have a few degrees more advance than dohc kas. For reference, peak torque and 0 psi, I run 26 (or maybe 28) degrees (where the dohc shows about 24).
Post by adamky »
According to my notes, that is the map for a '91 KA24DE manual trans.
Adrenalin
Post by Adrenalin »
No that's great. Not doubting you guys, I was just a little surprised at the the amount and quick increase of advance at low rpm.
Excellent info. Many thanks. I'm sure this will help.
tchida14
Post by tchida14 »
Great, now I have something to base my single cam maps off of, not just random guessing! 8)
How does the load relate to psi or kpa? Any conversion that would be useful?
EDIT:
My only concern now is the drastic differences I have noticed in the mid rpm, mid load range compared to my map that I beat the crap out of with no reliability issues or signs of detonation.. After translating that map to my tunerstudio map, I am seeing up to 10 degrees difference and more in other places. I do know that I didn't translate that map as seen above perfectly over to my 12x12 map, but that is a big difference in timing, big enough where I lowered the majority of it by a few degrees. I will attach the tune that i modified from the stock one provided in this thread so you guys can take a look if you'd like.
CurrentTune.msq
(111.63 KiB) Downloaded 251 times
Matt Cramer
Post by Matt Cramer »
If you are using a MegaSquirt, grab the timing map from the MSPNP base maps.
http://www.megasquirtpnp.com/mspnp2_maps.php
We didn't try translating the stock map into MegaSquirt format; they were generated by dyno tuning relatively stock engines.
tchida14
Post by tchida14 »
Matt Cramer wrote:If you are using a MegaSquirt, grab the timing map from the MSPNP base maps.
Awesome, Matt! Great link there, i'm not sure how i haven't stumbled upon that yet, but that sure answers my questions. I feel much better about my ignition map now! :mrgreen:
