How to build a KA24DE
koukika240sx
Post by koukika240sx »
ARP studs do not stretch. thats why they are reusable.
rhd
Post by rhd »
are you talking to me?
and yes, arp's do stretch...they just arne't tq to yeild. ALL bolts stretch
joshds25
Post by joshds25 »
i just wanted to post on this thread agin to bring it back to life this should have been a sticky??? what you say? :!: :arrow:
Kilten_one
Post by Kilten_one »
joshds25 wrote:i just wanted to post on this thread agin to bring it back to life this should have been a sticky??? what you say? :!: :arrow:
a link to this thread is posted in the hall of fame under engine parts related
joshds25
Post by joshds25 »
opps sorry :roll: my bad
jdmpurest
Post by jdmpurest »
dont foget to always assemble your engine in an environment that is 68.4 degrees celcius. that is the temprature of the engine build room at the factory.
doggunracing
Post by doggunracing »
jdmpurest wrote:dont foget to always assemble your engine in an environment that is 68.4 degrees celcius. that is the temprature of the engine build room at the factory.
Wow, it's 155.12 degrees fahrenheit in the build room? I would go on strike... :lol:
'97 SE SC50 KA-T
Marcus
Wearer of Missing G-Strings!
Post by Marcus »
That's what I was thinkin....that has to suck.
Hell I'm in Kansas so it's that warm in the summer anyways. 8)
ispentallmymoneyontires
Post by ispentallmymoneyontires »
so basicly i can build an engine any time outdoors here in florida, sweet.
-joking
There are many paths to Enlightenment: but no one said they can't be taken sideways.
89'hatch rustolum black/96'motor s13 new trans/OBD1 convert/F1 flywheel/DSS steel driveshaft/headers, testpipe, egay N1dual/ JGS poly engine, tranny/ Cory's Coil mod
RIP 480sx
felix
Post by felix »
very best post ever. i'm about to do this myself and need all the help i can get!
thanks alot
tunedis95
Post by tunedis95 »
wow ....this is freaken awsome....i've been looking for something like this....great job on the write up...great pics too.....eric
ZENKI!!!!CHOUKI!!!!!KOUKI!!!! and 350ZZZZZZZZZZZZZZZZ
EstoMax
Post by EstoMax »
hey man with the ring gap you mean 0.017 and 0.019 right not 0.0017 and 0.0019? :o
and also wouldnt you want the first ring to have more clearance (since more heat hits it) instead of having first ring a little less gap and 2nd ring more?
Marko
95 s14 kaT
t3/t04e (60 trim), bikirom, groundzero mani/dp, 82 lb AMS FS
94 d21 kaE 4x4 stock
Java
Post by Java »
Ive got a question (like i always do) Whats tools did you need to have to assemble the short block? measuring wise. Im doing mine very soon (like in a few days) and i was curiouse what all i would need other than a ring compressor and a fealler gauge.
240'less, I may have lost the battle but the war is not over yet!
EstoMax
Post by EstoMax »
you also need a file to grind the rings down.. a hand one will take a long time, i set a dremel up sideways and used that, only put the ring end on there for 2 sec at a time and then go remeasure cause it eats it down quick :D
95 s14 kaT
Joel07
Post by Joel07 »
The idea behind a larger second ring gap is that combustion gas tends to get caught in between the top and second rings, and if it builds up enough, will cause the top ring to "flutter" and lose seal. So by opening up the second ring slightly, the small amounts of combustion gas just go into the crankcase rather than making the top ring lose seal. This is the same reason I will never use gapless second rings in a motor, and the same reason many pistons have a groove cut between the top and second rings.
Java
Post by Java »
why does the sound of that scare me :? grind down the rings.. I guess i need to some research on that :lol:
Projex240
Post by Projex240 »
mine are at 22 and 22
Its what ivan told me would be a good rign gap with boost and nitrous.
-Josh
LocAss24
Post by LocAss24 »
Wow, great post. Thank you for putting out the time for this. You've just given me that little extra encouragement to rebuild my spare KA.
wildbama37
Post by wildbama37 »
Projex240 wrote:mine are at 22 and 22
-Josh
GRIND down the rings? are you serious? is this really a good idea ?
SleepyS-14
Post by SleepyS-14 »
It is a requirement. You have to set the ring end gaps correctly. Just take your time because if you nick the actual ring surface(that contacts the cylinder wall) then you have to get a new ring.
Beer, the cause of, and solution to all of lifes problems.
SOHC S-14...
EstoMax
Post by EstoMax »
btw do you also lube the rod bolts with the arb lube or do you leave those dry for torqueing?
95 s14 kaT
SleepyS-14
You have to use the lube. A dry torque is not an accurate torque.
SOHC S-14...
Java
Post by Java »
where did you buy that plasti gauge :oops: im also reading that they have different packages PL-A, PL-B ect. ranging from different measurments i imagine. Where did you get yours and what package number did you get?
wildbama37
bump for the plastigauge question!
ghostchild316
Post by ghostchild316 »
You can get it almost any parts store.Trust me,I know,I work at an auto parts store... :wink:
Dead account. Send pm's to "Alonso" from now on...
Java
Post by Java »
what mm package should i be looking for? they have for example: .010 through .050 next mm package would be gauging from .060 through .100 Dont know if I explained that right or not but i think youll know what i mean. Basically i dont know which mm im looking for to measure what i need to for the assembly of the shortblock :oops:
Also one more question, what did you pay to have the block: Hot tanked, magnafluxed, bored, honed, and redecked. Im having mine done at a local shop and they quoted me $900+ for Rods/Crank ShotPeend, Block Tanked, Maged, Bored, Honed, Cleaned, and Balanced. I thought at first they included assembling it aswell.. but i called them and they said it didnt.. does $900 sound right for all that???
NHn00bie
Post by NHn00bie »
bump for plasiguage package ???? and is decking nec. when building?
wildbama37
i guess just look at what the clearances are SUPPOSED to be and then by the plastigauge that has the clearance within the range of the plastigauge
lestat
Post by lestat »
great post. you are my hero.
Ngen-Head
Post by Ngen-Head »
pics dont work, anyone know why?
