z32 maf wiring
Locked
ballinnmiami240sx
z32 maf wiring
Post by ballinnmiami240sx » Mon Mar 06, 2006 12:14 pm
I found this pic over on nico and I want to make sure this is the way you guys are wiring your z32 maf N62 into your DE's. I'm asking b/c tonight I will wire in my mafs
ballinnmiami@yahoo.com
13.9 @ 7 psi 2.3 60ft.
Globalsilence
Post by Globalsilence » Mon Mar 06, 2006 12:46 pm
Yes that is correct, pay close attention to the notches on the top and bottom of the maf, there are 2 notches on one side and 3 on the other, this is critical so you get the wiring right. When i first did mine it was wrong and i smoked the MAF.
nüdelkopf
Post by nüdelkopf » Sun Mar 19, 2006 9:24 pm
I know this is an old post but are the maf signal and 12v wires just running from/to the wiring harness and maf plug or are they going elsewhere (like ignition) or something
kind of confusing cause the drawing has angled lines and #3 (the red one) looks like the wire is spliced in the middle and is running somewhere else besides the maf and harness
im gonna try to wire my maf up in the morning and any help would be appreciated
nismo200sx16
Post by nismo200sx16 » Mon Mar 20, 2006 3:12 am
no its just stright connections. wires go stright to the ecu. it just looks like that in the drawing caus some one drew it up in paint shop or some programe like it. so just cut your harness and wire it stright up. and sodder the wires.
sr20det powered s12 85
ka24det powered s14 95/98jdm front
ka24de powered s13 93
http://www.cardomain.com/ride/627008
http://www.cardomain.com/ride/2307235
ballinnmiami240sx
Post by ballinnmiami240sx » Mon Mar 20, 2006 2:08 pm
Notice the tabs on the drawing. Same as the plugs. Can't go wrong. I did it that way and it works.
SLOW_KA24E
Post by SLOW_KA24E » Mon Mar 20, 2006 4:00 pm
thanks for that picture ballinnmiami240sx, makes it even easier.lol
240sxvaj
Post by 240sxvaj » Wed Feb 27, 2008 3:18 pm
thanks for this
shift_76
Post by shift_76 » Mon Jun 02, 2008 3:52 pm
ok sorry for bringing back a topic from the dead but are we 100% sure this is the correct way to wire in a z32 (300zx maf) into a 1995 240sx harness with a ka24de ? Thanks
Shift_
go find something to do
Shift_
skott.b
Post by skott.b » Fri Jun 20, 2008 6:03 pm
yeah it is. that was wired into an s14 as well. as well i have done teh same on my S13.
~skott
s-14
Post by s-14 » Tue Jul 29, 2008 11:07 pm
Alright i wired my n62 maf exactly like this but my car idles like sht could it be that the down pipe has a leak? because it has a leak. can someone let me know what colors the actual wires are and what color goes to what thx need soon someone plz look at yours and let me know, and my exhaust smokes like sht also dont know why but it smokes a lot doesnt smell like oil or coolant, just smells like exhaust it's still an open pipe too.
driftersgonewild
Post by driftersgonewild » Fri Sep 26, 2008 12:44 am
this may be off topic but whats the setting for a z32 maf on a SAFC 2?? :?:
"I WANA GO FAST!!!"
-Ricky Bobby
jmac636
Post by jmac636 » Fri Oct 10, 2008 12:29 pm
Well if your running an Ecu set up to run stock maf then it should be 02 in 05 out. If you have tuned ecu for z32 maf then it should be 02 in 02 out. Stock maf and stock ecu are o5 in and 05 out.
02in 05out= stk ecu +z32maf
02in 02out= z32ecu tune+z32maf (ecu tuned for z32maf)
05in 05out=ka24de ecu+ka24de maf
jmac636
Post by jmac636 » Fri Oct 10, 2008 12:32 pm
good info about the z32 maf. It would be a cool sticky!
Bailniss
Post by Bailniss » Thu Oct 16, 2008 10:20 pm
should be sticky good info
njd07
Post by njd07 » Fri Oct 17, 2008 8:14 pm
pretty simple.... you got signal which is thin white wire , then you got power which is super thick white wire...rest are grounds
Sil#2
Post by Sil#2 » Mon Nov 07, 2011 6:58 am
Sorry for bringing back this old post, but the pics no longer work. Does anyone still have this pics and if so, can they send them to me? When people say "harness side". I assume that means you're look into the plug?
Is the thick white wire the Power? And the thing white wire the signal?
Post by supakat » Mon Nov 07, 2011 7:54 am
It is the same one I posted in your thread.
Locked
