www.ka-t.org
KA-T.org Forumswww.ka-t.org
KA-T.org Forums
FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups  Timeslip DatabaseTimeslips  RegisterRegister   ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Go to
www.ka-t.org Forum Index -> SOHC KA-T
DIY Emissions Removal SOHC
Goto page 1, 2, 3  Next
Post new topic   Reply to topic
View previous topic :: View next topic
Author Message
glacier985
PostPosted: Mon Mar 20, 2006 7:59 am    Post subject: DIY Emissions Removal SOHC Reply with quote
Ka24e DIY Emissions Removal
1. Stock Intake
-- a. Emissions Parts
---- i. Location
2. Other Emissions Parts
-- a. Location
3. Vacuum lines
4. What to keep and remove
5. Going a Step Further
6. Disclaimer
Tired of looking at that stock intake and wondering what you can do to clean it up? Maybe add some power while you’re at it to? Well let’s take a look at what we can remove.
Here is a diagram from the FSM of the engine and emissions control devices. They are numbered for easy reading.
Stock intake
1. EGR control valve, this controls the quantity of exhaust gas that is let into the intake manifold. It is located on the back of the intake and has a metal tube that goes to the exhaust manifold. This can be removed and no codes should be thrown and no check engine light. If not a 100K ohm, 1/4 watt resistor in place of the EGR temp sensor in its place to fix it.
2. BPT valve, this monitors the exhaust pressure to activate a diaphragm that controls the EGR vacuum. It is located on the back and inside of the plenum and is on top. Really easy to spot. Remove it and no code will be thrown.
3. FPR, this is on the back of the fuel rail and is necessary for the engine to run properly. DO NOT remove it.
4. Pressure regulator control solenoid valve and SCV control solenoid valve. These are located on the back of the head, along with a bundle of hard lines and vacuum hoses. Remove them and that’s it, no codes.
4a. SCV actuator (not pictured), since the SCV solenoid was remove, this must be removed. This is located on the back of the intake manifold. It’s on the right side and controls the butterflies. Once it is removed you can do away with them as well. Each one is held in by two screws. Remove all four plates, the small screw in the middle of the intake and then pull the rod out. You can either have the rod holes welded shut or use JB weld.
5. Air regulator, located on the inside of the intake plenum, basically helps the car warm up when it’s cold. I kept this and if you drive your car in the winter or start it when it is cold you should do the same. Warmer climates probably don’t need this.
6. EGR Control Solenoid, toward the front on the left side and bottom of the intake. EGR is gone, so remove it.
7. IAA unit includes the ACC valve. This is located on the back of the intake plenum and controls the idle of the motor. Its one of the few things I kept and I believe is necessary for a good running, street-able engine.
Other Emission Parts
8. AIV case and control solenoid. It’s the big ugly mess on the drivers side strut mount. You’ve probably got rid of it already, but if not, go ahead and throw it in the trash, but be sure to plug the hole in the exhaust or the metal hose.
9. Charcoal canister, big black cylinder on the driver’s side front of the engine bay. Remove, the vacuum lines come later.
Vacuum Lines
After the removal of all the emissions comes the question of vacuum lines. On my current NA setup I have two vacuum lines, both maybe 2 inches long. How did I do this? Easy, if you have the same setup as me every vacuum line can be removed, except for two. The bundle of hard lines that run down the middle of the intake can be removed and the lines that run to the charcoal canister can go to. I went as far as even removing a hard line that runs from the transmission tunnel to the charcoal canister. It’s the fuel tank vent and the hose needs to be left unplugged.
Now what lines to keep? The FPR will now be the only thing that needs a vacuum source. All I did was run a line from the intake hard line to the hard line on the fuel rail and then a line from that to the FPR.
What to Keep and Remove
Keep
i. Air Regulator
ii. AAC unit
iii. FPR
Remove
iv. EGR
v. BPT valve
vi. PR and SCV solenoid
vii. SCV actuator and butterflies
viii. EGR control solenoid
ix. AIV case
x. Charcoal Canister
Things Kept
Want to go the extra mile for the clean look? Here’s a few tips on what to do.
• Extend the injector plug wires and other harness plugs and run the wiring harness under the intake.
• Grind off the BPT valve tabs (pictured)
• Remove coolant lines running on plenum and grind off hard lines and block left after removal. (pictured)
• Remove vacuum source on the left side of plenum
• Grind off ECCS
• Paint Cast-Coat Aluminum for a nice finish
Disclaimer
- I am not responsible for any harm done to your engine by following this guide to removing emissions. I’ve had no problems in the year I have had them removed. If you live in an area with emissions testing I suggest you do not remove anything. Any questions and/or concerns can be sent through a PM or email.
All text and images Copyright Justin Glaser 2006
_________________
1990 240sx SE, 96K, ka24eT Upgrade Time
www.ka24et.com coming soon
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
P4rD0nM3
Hella Old School
PostPosted: Mon Mar 20, 2006 9:33 am    Post subject: Reply with quote
Hmm, looks like I forgot some stuff to take out. Goodx stuff bro good ****...thanks.
_________________
z0mg.
Back to top
JP
PostPosted: Wed Mar 22, 2006 6:51 am    Post subject: harness Reply with quote
what did you do with the wiring harness connections
Back to top
glacier985
PostPosted: Wed Mar 22, 2006 7:07 am    Post subject: Re: harness Reply with quote
I extended the plugs, by cutting them and soldering new longer piece of wire between the harness and the plug. I then ran the wiring harness under intake manifold. I think I needed to extend all four fuel fuel injectors, the two grounds that bolt on the head, coolant temp sensor connector, and the ground beside it. Everything else was long enough. I can get soe pictures for you if you'd like.
_________________
Back to top
nis720
PostPosted: Thu Mar 23, 2006 2:58 pm    Post subject: Reply with quote
Do you have an overall shot of the intake?
Good info...... specially now that I'm preping my intake.
_________________
Still plays with trucks
http://members.cardomain.com/nis720All anybody wants is a normal life and a cool car... most people settle for the car - Titus.
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
glacier985
PostPosted: Thu Mar 23, 2006 6:44 pm    Post subject: Reply with quote
No, but I will have one tomorrow when I actually get home from work when it is still light outside.
_________________
Back to top
morodo_s13
PostPosted: Sun Mar 26, 2006 10:03 pm    Post subject: Reply with quote
nice writeup,
do you have pictures of how clean yours looks?
Back to top
glacier985
PostPosted: Tue Mar 28, 2006 7:40 pm    Post subject: Reply with quote
Finally rembered to get some pictures......
_________________
Back to top
silviasxy
PostPosted: Tue Mar 28, 2006 8:28 pm    Post subject: Reply with quote
Good write-up...everything should be good for a turbo too right? And what is running over your valve cover? Question
Looks good though!! Very Happy
_________________
- Brit
'89 240sx coupe - Silvia/KA24ET project
Back to top
View user's profile Send private message Visit poster's website AIM Address
morodo_s13
PostPosted: Tue Mar 28, 2006 8:36 pm    Post subject: Reply with quote
silvia, that line is the turbo oil feed line, and that car has a turbo,
lol, glacier if i print several of your engine bay pics i can puzzle up how your engine bay looks lol Laughing
Back to top
silviasxy
PostPosted: Tue Mar 28, 2006 8:55 pm    Post subject: Reply with quote
My bad, I haven't ever seen the oil line run over the valve cover.
And that answers my other question too! Smile
_________________
- Brit
Back to top
glacier985
PostPosted: Tue Mar 28, 2006 8:56 pm    Post subject: Reply with quote
I'll have some full engine bay pictures up soon, just waiting on the right size t-bolt clamps.
_________________
Back to top
nis720
PostPosted: Mon Apr 03, 2006 6:47 pm    Post subject: Reply with quote
When you removed coolant hard lines running on the upper plenum did you have to weld something?
I started grinding on mine and soon noticed there's a cavity in the center and now have a hole in my intake. I'm going to have to get it welded before I take it to get polished.
_________________
Back to top
nis720
PostPosted: Mon Apr 03, 2006 7:39 pm    Post subject: Reply with quote
Here's a pic of my intake..... Some welding and reinforcing will fix it.
_________________
Back to top
samurai808
PostPosted: Tue Apr 04, 2006 1:47 am    Post subject: Reply with quote
Hey, ive been watching/ learning on these boards for a while now but i have a question for you guys modding the plenum... i just gotta tell ya that it look slike some good work, look snice and clean!!! other than that, i just wanted to know if the coolant lines on the side of the plenum and the front of the throttle body have any actual use? lol i wanted to just re route the coolant line from the bottom side pipe to the little pipe coming out of the manifold radiator thing but i wasnt sure if that would affect anything.
if ya could lemme know how safe it is to do away with the lines going to the plenum and throttlebody that would be fantabular lol thx =P
btw, thx for the writeup, really cleared things up for me!
Back to top
glacier985
PostPosted: Tue Apr 04, 2006 7:27 am    Post subject: Reply with quote
Yea I had to get mine welded closed, I also got rid of a vac hardline on the plenum. The one right up next to the throttle body.
Samurai, those coolant lines are referred to as the "coolant bypass". There suppose to heat the air coming into the intake to help warm up the motor I think. I just removed the lines and connected a hose from the small hardline coming from the intake coolant connection and then it goes to the small hardline that comes out of the hardline that runs under the manifold to the heater core. It's hard to get pictures, but I have a couple spare manifolds that I can show you pictures if you need them.
_________________
Back to top
nis720
PostPosted: Tue Apr 04, 2006 7:57 am    Post subject: Reply with quote
Ok... I thought I messed up.... I'll have to find someone that can weld it shut..... I decided to get it looking like yours, I removed the rest of it and now I just need to have the gapping hole covered.
Did you weld it yourself?
_________________
Back to top
glacier985
PostPosted: Tue Apr 04, 2006 4:28 pm    Post subject: Reply with quote
no, i don't know how to TIG yet, but I plan on learning in a year. I had my uncle do it, he also did the inlet and outlets on my intercooler.
BUt thats exactly what my hole looked like, if I was you I would remove the two tabs on the back of the plenum, unless you plan on keeping the BPT valve.
_________________
Back to top
nis720
PostPosted: Wed Apr 05, 2006 10:38 pm    Post subject: Reply with quote
I plan to keep some emissions stuff (Cali smogging) so I'm keeping the BPT tabs.
$40 later the hole is filled.
_________________
Back to top
P4rD0nM3
Hella Old School
PostPosted: Thu Apr 06, 2006 6:33 pm    Post subject: Reply with quote
Can I ask the whole engine bay pic Mr. Glacier? For reference purposes...
_________________
z0mg.
Back to top
glacier985
PostPosted: Thu Apr 06, 2006 6:38 pm    Post subject: Reply with quote
Hi-res? I'll get it tomorrow, 3.1 MegaPixels is the biggest I can get. Any other pictures just ask.
_________________
Back to top
P4rD0nM3
Hella Old School
PostPosted: Thu Apr 06, 2006 9:17 pm    Post subject: Reply with quote
OK i'll ask thru PM. Bec, I dunno those seal thingies and vaccum lines...
_________________
z0mg.
Back to top
slayton
PostPosted: Wed Apr 12, 2006 8:33 pm    Post subject: Reply with quote
so is there any way to remove everything exept for the secondary controlers, fpr, iaa, and air regulator without having any any engine codes coming up?? instrustions??
_________________
Jwolf
http://www.cardomain.com/ride/2594544
Back to top
glacier985
PostPosted: Thu Apr 13, 2006 3:20 pm    Post subject: Reply with quote
No Engine codes should come up with a ka24e. I personally have never seen a check engine light on my car.
_________________
Back to top
sidwin
PostPosted: Sun Jun 04, 2006 1:17 am    Post subject: Reply with quote
so when you pull the egr off what do u use to cover up the holes? does anyone make any kind of EGR plates that you could bolt up after you remove it?
Thanks,
SId
_________________
Sid Nguyen
www.sidwin.com
95 Toyota Supra 680 RWHP
90 Nissan 240sx
01 Lexus GS300
01 Toyota Seq. Limited
Back to top
View user's profile Send private message AIM Address
P4rD0nM3
Hella Old School
PostPosted: Sun Jun 04, 2006 6:24 am    Post subject: Reply with quote
California cars will throw the code 32 if you remove the e.g.r.s
_________________
z0mg.
Back to top
sidwin
PostPosted: Tue Jun 06, 2006 8:59 pm    Post subject: Reply with quote
someone needs to make a post of things u can pull off it u keep the intake manifold on the car. I don't have a welder near by that i can get to weld up holes. and what about the egr holes?
thanks,
sid
_________________
Sid Nguyen
www.sidwin.com
90 Nissan 240sx
01 Lexus GS300
Back to top
caoboy
PostPosted: Tue Jun 06, 2006 11:31 pm    Post subject: Reply with quote
for california cars, i believe you can wire up a resistor to fool the egr. even though im in california, i have a federal car (no CEL in the gauge cluster) and i think i could get away without having to put in resistors.
Back to top
glacier985
PostPosted: Wed Jun 07, 2006 7:09 am    Post subject: Reply with quote
thanks,
sid
Just dont grind the coolant lines off the pelnum and you won't need to weld anything. And the egr just get a piece of sheet metal and cut out a plate to cover it up and use some sealant so it stays.
_________________
Back to top
SkylineKin
PostPosted: Wed Jun 07, 2006 6:24 pm    Post subject: Reply with quote
awseome write up, I will definitly be using this information.
Back to top
sr20what?
PostPosted: Wed Jun 07, 2006 6:27 pm    Post subject: Reply with quote
this is great info
one question, can i ditch the whole charcoal canister and the lines attached to it? I know you answer it but just wanted to check.
Back to top
sidwin
PostPosted: Thu Jun 08, 2006 8:00 pm    Post subject: Reply with quote
once u dump the charcoal canister there is going to be one line that is used for the gas can to vent. that line i would suggest you find a way to plumb it back into the intake if you don't want to smell the fumes.
I pulled my egr hose and capped it off. i also removed the solenoid that was on the top of the intake manifold.
thanks,
sid
_________________
Sid Nguyen
www.sidwin.com
90 Nissan 240sx
01 Lexus GS300
Back to top
sidwin
PostPosted: Thu Jun 08, 2006 8:10 pm    Post subject: Reply with quote
can someone take a pic of the egr solenoid? i got the BPT off and capped all that stuff and i capped off the egr. I wish someone made egr block off plates like the do in the supra and then i could strip that guy off the intake and then plug the exhaust port too.
Thanks,
Sid
_________________
Sid Nguyen
www.sidwin.com
90 Nissan 240sx
01 Lexus GS300
Back to top
glacier985
PostPosted: Thu Jun 08, 2006 8:21 pm    Post subject: Reply with quote
Thanks,
Sid
The EGR solenoid is about directly underneath the throttlebody if I remember correctly. It's hard to miss.
_________________
Back to top
nelson240sx
PostPosted: Sat Jun 10, 2006 4:07 pm    Post subject: Reply with quote
they do make egr block off plates for the ka24e check ebay. I just unbolted the top half of the egr the big ugly part and use the smaller piece that bolts to the throttle body. I took a piece of sheet metal and stuck it in between the intake mani and the egr and bolted it back down. I did that because i am cheap but you could spend i think it is 20$ on ebay and buy one.
_________________
Boosted since 06-06-2006
Tuned on e85 as of 3-30-2009
KA24E-T sold 10-3-2009
KA24DE purchased 12-5-2009 (here we go again)
R34SR wrote:
"Honda Guy: dude why are you towing that trailer with your car!!?
240 guy : because i can"
Back to top
Display posts from previous:
Post new topic   Reply to topic    www.ka-t.org Forum Index -> SOHC KA-T All times are GMT - 8 Hours
Page 1 of 3
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Template/Skin (ChunkStyle) by ©Russellc (TheChunk.no-ip.com)
Best viewed in Mozilla Firefox 0.8
Powered by phpBB © 2001, 2002 phpBB Group
