| Author |
Message |
seanc Belongs To The TOP CONTRIBUTING MEMBERS!
Joined: 29 Nov 2005 Posts: 2555 Location: Lake Stevens, Wa
Posted: Tue Oct 16, 2007 2:58 pm Post subject: Taures fan Wiring How To |
this is a basic diagram for wiring a taures fan, the low speed will crank on with the ignition turned on and the high speed is manually controlled by a switch in the cockpit. if anyone wants and little changes done or a custom one, post it up and i will get it done asap!
| Back to top |
zenkizen Knows Some Stuff About 240's!
Posted: Wed Oct 17, 2007 8:23 am Post subject: |
I'm using the stock radiator fan relays, but just to keep things simple, lets do the low fan setting first.
what wires go where?
I know that the top prong on the relay goes to the low fan wire. what about the other 3 prongs.
here's a crappy diagram of the prong layout.
Also, which hot ignition wire do i tap?
Ignition Switch Harness:
+12v constant = white
Ignition Power, Ignition = black/red
starter wire (+12v) = black/white
ignition 2 (+12v) = black/yellow
accessory (+12v) = white/blue _________________ zen.....
| Back to top |
Posted: Wed Oct 17, 2007 9:32 am Post subject: |
Just found out the functions of the prongs but still have not idea what wires go where
here's another crappy diagram
| Back to top |
undesiredshoe Belongs To The TOP CONTRIBUTING MEMBERS!
Joined: 07 Feb 2006 Posts: 1759 Location: Sheboygan, WI
Posted: Wed Oct 17, 2007 12:14 pm Post subject: |
5 goes to the positive power source. 3 goes to the fan. 2 goes to a switch or something. 1 goes to a ground. _________________
Stock block ka24e - 12.81 @ 113mph |
| Back to top |
