| Author |
Message |
R@mon KA-T.org Featured Ride
Posted: Mon Jun 09, 2008 6:50 pm Post subject: Junkyard Power steering delete brackets |
For all you guys who eliminated your power steering, this is a simple/cheap way to run a single belt for both your water pump and alternator.
parts needed:
SOHC Lower Alt bracket
SOHC Upper Alt bracket
SOHC water outlet (DOHC hits belt)
35" 3 rib belt
the water pump pulley and the outer most crank pulley are 3 rib but the alternator is 4 rib so you need to run it on the inner most set of ribs (as shown in the pics)
You'll need to use a spacer between the alternator and the upper alt. bracket. I used a exhaust manifold washer and it worked perfectly. you will also notice the belts will hit a certain spot on the upper alt bracket, but its nothing very minor grinding wont fix, you can see the spot on the 7th picture down.
The factory lower hose also lined up fine.
tested it to 8k+ rpm, with no issues.
Big thank you to my buddy Anthony (1991silvia), who is the one who figured out this setup.
| Back to top |
ka_s372 Knows Some Stuff About 240's!
Posted: Mon Jun 09, 2008 7:13 pm Post subject: |
| very nice post R@mon !! two thumbs up !! |
| Back to top |
Liger Encyclopedia-Nissan
Posted: Mon Jun 09, 2008 9:17 pm Post subject: |
| Thank god someone has finally found a way to use various parts to do this. +1 for you |
| Back to top |
Craving4Boost Knows Some Stuff About 240's!
Joined: 15 May 2005 Posts: 368 Location: San Francisco, CA
Posted: Mon Jun 09, 2008 9:58 pm Post subject: |
| hell yeah nice write up! but instead of grinding down the upper bracket...can't you juse use the outter most ribs of the alternator pulley? That would shift the belt towards the right correct? Unless that slight angle would not be fit for high rpms?? regardless...THANK YOU |
| Back to top |
Posted: Mon Jun 09, 2008 10:04 pm Post subject: |
| Craving4Boost wrote: | | hell yeah nice write up! but instead of grinding down the upper bracket...can't you juse use the outter most ribs of the alternator pulley? That would shift the belt towards the right correct? Unless that slight angle would not be fit for high rpms?? regardless...THANK YOU |
To line up correctly to the other belts, it needs to be on the ribs closest to the motor. Ive been meaning to see if the sohc crank pulley has a removable outer pulley like the twin cam one, and if it does, see if its 4 rib. If thats the case, you can make it a true 4 rib design also, just swap the water pump pulley to a SOHC one. Ill have to check it out. |
| Back to top |
Posted: Mon Jun 09, 2008 10:09 pm Post subject: |
| great...let us know how that goes. Have you driven your car with no PS yet? if so, how is it? |
| Back to top |
Posted: Mon Jun 09, 2008 10:31 pm Post subject: |
| Craving4Boost wrote: | | great...let us know how that goes. Have you driven your car with no PS yet? if so, how is it? |
i took the PS off the car the day after i bought it. I dont mind it at all.But i guess ive just gotten used to it. |
| Back to top |
ZiG Dont Question My Nissan Knowledge
Posted: Mon Jun 09, 2008 11:12 pm Post subject: |
Wow, I like it. _________________
| Back to top |
smracing Dont Question My Nissan Knowledge
Joined: 22 May 2006 Posts: 706 Location: Carlsbad, NM
Posted: Tue Jun 10, 2008 5:28 am Post subject: |
| Nice, no more machining. |
| Back to top |
1wheelwonder Encyclopedia-Nissan
Joined: 25 Mar 2005 Posts: 1258 Location: Decatur, Alabama
Posted: Tue Jun 10, 2008 5:49 am Post subject: |
Wow, thanks R@mon. _________________ DIY (Because I'm broke bi*ch)
Myspace.com/1wheelwonder
Currently rocking a .020over bare block that's sitting butt naked on the garage floor!
What's next, hmmmmmmmmm? Maybe whatever's in this huge crate holds the key to this answer. |
| Back to top |
drifty240 Dont Question My Nissan Knowledge
| Back to top |
1991Silvia 240sx Wannabe
Posted: Wed Jun 11, 2008 12:45 pm Post subject: |
| R@mon: im petty sure the crank pulleys are the exact same part.... |
| Back to top |
Posted: Thu Sep 18, 2008 8:33 pm Post subject: |
sorry to bump an old thread but I just wanted to say I finished doing this today and it works great. The engine bay is so much cleaner now. I didn't get a chance to drive it much because the car is stuck behind a bunch of other cars. But I did move it back into my garage at very slow pace and the steering doesn't even seem that bad honestly. We'll see when I give it a spin tomorrow.
Only bad thing I can say is that I had to drain the coolant to change the water outlet. I was worried the RTV wouldn't harden if the housing was still moist. If your motor is already out then obviously you don't have to.
I would post up pictures but r@mon's pics are pretty clear cut. |
| Back to top |
Posted: Thu Sep 18, 2008 8:40 pm Post subject: |
also I weighed everything in this ghetto bag and it weight around 20-25lbs without the fluid. I also did not include the hardlines. This wasn't a very good scale neither so I'm not sure how accurate it is. I know wikipedia and stuff has the numbers also but I just wanted to give my input as well.
Going to be taking out my spare tire and jack tomorrow. Who needs a spare tire when you have cell phones  |
| Back to top |
Posted: Thu Sep 18, 2008 8:46 pm Post subject: |
| Also, for the long bolt that connects the alternator to the lower bracket, the normal locking nut gets in the way of the bottom bolt of the bracket. If you guys see in r@mon's 8th picture, he uses a slimmer locking nut. I personally was lazy and just didn't put a 3rd bolt in. You guys think it will be ok? the 2 bolts holding it in feel really solid enough but damn the alternator is heavy.... |
| Back to top |
Kirk Knows Some Stuff About 240's!
Posted: Fri Sep 19, 2008 5:06 am Post subject: |
This is an amazing post. Great job! Sticky somewhere??? _________________
| Back to top |
dopeassjackson Belongs To The TOP CONTRIBUTING MEMBERS!
Joined: 30 Nov 2005 Posts: 2537 Location: hudson valley NY
Posted: Fri Sep 19, 2008 5:38 am Post subject: |
a 3 rib belt on a 4 rib pully isnt going to last very long. _________________
KA24ET RB20 turbo, 460cc |
| Back to top |
Miami240 Dont Question My Nissan Knowledge
Posted: Fri Sep 19, 2008 6:04 am Post subject: |
| dopeassjackson wrote: | | a 3 rib belt on a 4 rib pully isnt going to last very long. |
Why not? _________________ -- John Force -- |
| Back to top |
Posted: Fri Sep 19, 2008 10:12 am Post subject: |
because he said so!!!
Always believe what you hear on the internets.
LOL
 _________________
| Back to top |
Posted: Fri Sep 19, 2008 1:00 pm Post subject: |
| anyone else tried it yet? |
| Back to top |
Posted: Sun Sep 21, 2008 4:48 pm Post subject: |
| Craving4Boost wrote: | | anyone else tried it yet? |
the same setup has been on my friends car for a while (about 7 months).....works fine... the car is daily driven.... the 3 rib belt is fine... |
| Back to top |
PattonN Dreams of owning a 240!
Joined: 04 Apr 2007 Posts: 80 Location: Gahanna, Ohio
Posted: Mon Sep 22, 2008 7:11 am Post subject: |
mine has been setup like that for a year so far.. Belt it still good. _________________ ~89 fastback
~ka24et |
| Back to top |
Posted: Mon Sep 22, 2008 12:55 pm Post subject: |
| everything now is 100% done. Honestly it's going to take some getting used to because San Francisco is very twisty. This car will be a full drag car one day anyway though. With 2 hands it's not bad. |
| Back to top |
oes Knows Some Stuff About 240's!
Posted: Mon Sep 22, 2008 2:09 pm Post subject: |
| I am in the process of changing over, among other things. I am just glad to get rid of the leaky power steering mess and clutter. |
| Back to top |
Posted: Fri Sep 26, 2008 3:38 pm Post subject: |
| yeah my POS presure line kept leaking. Went to junkyard and got another one and a couple months later it starts leaking again. I said screw it it's coming out. |
| Back to top |
Chozen Knows Some Stuff About 240's!
Posted: Sat Sep 27, 2008 4:48 pm Post subject: |
Props to people who discover things like this. I bet it took some trial and error, but it was worth the effort. _________________ DIY or die. |
| Back to top |
| Back to top |
rob 2fast4u Knows Some Stuff About 240's!
Posted: Sun Sep 28, 2008 7:45 am Post subject: |
what do you do to the lines of the steering rack? do you just conect the pressure and return lines together ? _________________ fully built:
supertech 8.6:1
eagle H-beams
272BC cams
BC Dual springs
has t3/t04e 60trim need a bigger one for 25psi ???? s366 maybe
custom exh & intake manifolds
ebay ssqv bov
2.5"hotpipe, 3"coldpipe, Blow through MAF
AEM FIC,Zeitronix wideband, z32 maf
Bosch 1000cc inj, Twin walbro's, -8AN feed line,.... and lots more |
| Back to top |
Posted: Mon Sep 29, 2008 9:58 am Post subject: |
| drifty240 wrote: | some one makes this into a kit and sale it to me  |
junkyard has the kit  |
| Back to top |
Posted: Mon Sep 29, 2008 10:01 am Post subject: |
| rob 2fast4u wrote: | | what do you do to the lines of the steering rack? do you just conect the pressure and return lines together ? |
the hard lines on the steering rack I took off 2 of them. I only took off 2 of them because those were the only ones I really had to take off. The extra 2 behind the steering rack didn't really bother me. When I took off the first 2 lines, I just found 2 fittings that were close enough. i don't really worry much about leaking because I drained it pretty much completely.
Make sure you don't mess up the thread trying to find fittings because you never know when you're going to put it back in. |
| Back to top |
Posted: Mon Oct 13, 2008 6:13 pm Post subject: |
| How does no power steering with a power steering rack feel on the street for you guys anyway? |
| Back to top |
Posted: Tue Oct 14, 2008 8:43 am Post subject: |
it depends what area you're living in. If it's mostly open roads and easy turns, it's not bad at all.
Do you guys think I can pump fluid into the rack and then plug it back up to help ease the steering? Or will the pressure build up too greatly from not having any return? |
| Back to top |
Posted: Tue Oct 14, 2008 5:29 pm Post subject: |
lol judging from your question, it must be somewhat of a pita.  |
| Back to top |
Posted: Wed Oct 15, 2008 9:33 pm Post subject: |
| haha yeah a little bit. More on my dad though because sometimes he uses the car to run errands and he gets pissed all the time now. |
| Back to top |
Posted: Mon Oct 20, 2008 10:45 am Post subject: |
| anyone? |
| Back to top |
