707whp and 570ft/lbs @ about 35psi on e85
blacks13coupe
Post by blacks13coupe » Thu Jul 16, 2009 7:04 pm
Very impressive!
all shal perrish
Post by all shal perrish » Thu Jul 16, 2009 7:21 pm
bad ass dude. i am verry impressed! are you going to get bigger injectors and try to make more power, or, are you going to call it good with 700 hp lol
regardless, awsome job..
www.autovaughnperformance.com
if you have some, pm me
Post by Turbo24sxt » Thu Jul 16, 2009 9:36 pm
SECONDARY FUEL INJECTORS FTW!!
whats your timing looking like on this new tune?? and is your passengerside tire rubbing in that vid??
hotbox240
Post by hotbox240 » Thu Jul 16, 2009 9:54 pm
Did you spin the tires on the dyno when the boost hit? That was crazy :shock:
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
Post by Turbo24sxt » Fri Jul 17, 2009 11:58 am
hell yeah man ... well congrats on numbers .... keep it up ...
2200cc?? dont care for driveability i assume lol ... whats your base fuel pressure at?
i really wanna see what your timing map looks like ...
96silvia
Post by 96silvia » Fri Jul 17, 2009 12:19 pm
damn!!! nice numbers what is your setup? are you running a standalone management system? congratulations
s14fiend
Post by s14fiend » Fri Jul 17, 2009 6:25 pm
Nice work.
-Adam
pearl240sx
Post by pearl240sx » Sat Jul 18, 2009 6:08 am
thats insane man i like this car and glad to see your making progress
turbo2nr
Post by turbo2nr » Sat Jul 18, 2009 6:12 am
goddaamm finally 700whp! woot! congrats.
prob feels badass ringing it out to almost 8k, damm makes me want to build my motor even more now!
lets see some kills now zr-1s are calling lol
R.i.p. 97 s14
96 s14 ka-t
klattr1
Post by klattr1 » Sat Jul 18, 2009 12:21 pm
freakin' awesome! that's HUGE #'s. :)
Niclas_AB
Post by Niclas_AB » Sun Jul 19, 2009 2:07 am
Is that 19-20deg at 35psi :shock: Aint that very very much? do lower the spark angle where the engine has it's peak torque?
Niclas_AB
Post by Niclas_AB » Sun Jul 19, 2009 10:40 am
ah, then it feels a bit more right. If you don't mind me asking, but by how much do you lower? 4-5 degrees? Just trying to learn some basics of the ka timing.
Running 15degrees at 17psi should put me in the plenty safe area then I guess :D
Niclas_AB
Post by Niclas_AB » Sun Jul 19, 2009 12:27 pm
Yes, of course. Need to go to a dyno and do the rest of the tuning.
I also run on E85, that's why I'm so interested in your numbers,, not so many runing on it yet.
But big congrats on some awesome numbers!!! Very impressive!
leonl
Post by leonl » Sun Jul 19, 2009 1:47 pm
Very impressive number. Good luck with next mod.
Miami240
Post by Miami240 » Mon Jul 20, 2009 1:46 am
Niclas_AB wrote:ah, then it feels a bit more right. If you don't mind me asking, but by how much do you lower? 4-5 degrees? Just trying to learn some basics of the ka timing.
I used to run more timing than that on my completely stock ka on 93 octane fuel. Of course though i had a custom intake mani and a somewhat large turbo resulting in less peaky torque numbers.
12508 SW 117 Ct.
Miami, FL 33186
Ph: (305) 251-1995
2muchboostNY
Post by 2muchboostNY » Mon Jul 20, 2009 5:17 pm
wow killer build. I am new to the forums and just stumbled on your post and its crazy...I was wondering if you had a build list or to be more exact, i am wondering what type of rear end set up your running with that much power. I am assuming your using the 300zx transmission.
97kouki6262
Post by 97kouki6262 » Mon Jul 20, 2009 5:42 pm
psssshhhhh,....my moms camery did that much power with 87 oct, pulled back the banana exhaust, pulled the wiggle pins out, and took the spare tire out...seriously get on board ked..j/k, great numbers man, im about to follow suit though, i have got to get on this e85. So with that being said, congrats, and if you jump to 2200cc, i got first dibs on the 1600 lol... again, great job
