O&J Cams
O&J Cams
Postby tek_88 » Thu Oct 22, 2009 10:04 am
Okay, so I've been looking into cams and found the O&J cams...I was wondering if anyone is using their cams and what's the power band like, hows idle and did you have to mill the cam towers?...with my setup I'm aiming for 350hp and need to know if these cams will help my get their. I was really looking into their stage 2 270 dur and stage 1 mech 280 dur...
tek_88
Postby SleepyS-14 » Thu Oct 22, 2009 11:09 am
I would say the first upgrades anyone should do to the SOHC is:
Step 1- Get pioneer valve springs (like $35)
Step 2- Get solid lifters (O and J sells these)
Step 3- Get the stage 2 mech cam for O and J
Step 4- Set revlimiter at 7,500
Step 5- Beat that Sh1t like it owes you money
SOHC S-14...
SleepyS-14
Postby pwjm » Thu Oct 22, 2009 12:32 pm
whats the part # for those springs again?
pwjm
Postby tek_88 » Thu Oct 22, 2009 11:04 pm
okay, thanks...I guess I'll just do that and have the machine shop put it on for me...and where did you get those valve springs from?
tek_88
Postby Jackasknissan » Tue Oct 27, 2009 1:02 am
sleepy s14, what is the idle like on the stage 2's?
[quote="oaznbeasto"]
Hey 6 posts, Go **** yourself! learn something then post[/quote
Jackasknissan
Postby SleepyS-14 » Tue Oct 27, 2009 6:19 am
I run my idle with the throttle body cracked open with no idle control. So it is idling at about 18:1-25:1 afr. My idle is still pretty decent. Compression is going to be lower with this cam though. But who care, it rips!
SOHC S-14...
SleepyS-14
Postby sommmatt » Sat Nov 07, 2009 4:34 pm
Any before/after dyno numbers? Want to see how this affects the power band. Charts would be awesome.
sommmatt
Postby SleepyS-14 » Sat Nov 07, 2009 5:23 pm
actually I do. I dont have a camera to use right now but I will put in a few facts. You will be very happy.
Stock cam:
3500- 280wtq
4500- 265wtq
5500- 230wtq
6500- 200wtq
7000- 170wtq
3500- 190whp
4500- 240whp
5500- 270whp
6500- 250whp
7000- 225whp
O and J stage 2 mech cam
3500- 265wtq
4500- 320wtq
5500- 320wtq
6500- 275wtq
7000- 245wtq
3500- 170whp
4500- 240whp
5500- 325whp
6500- 335whp
7000- 325whp
Basic facts
-Added about 100whp at 7000rpms
-Added about 90wtq at 5500 rpms
-Meth added 30whp
-turbo added 20whp
So put together added about 50whp and 45wtq and completely changed the powerband from 3000-5000 to 4200-6800
SOHC S-14...
SleepyS-14
Postby Jackasknissan » Sat Nov 07, 2009 6:37 pm
any body play with the stage 3's im wondering how much more the extra lift, and duration helps up top
Jackasknissan
Postby SleepyS-14 » Sun Nov 08, 2009 10:06 am
I tryed the stage 2 and 3. He actually modifyed both of the cams cause they had way to much overlap. If you look at his specs for the cams, they are all a little less than they were. I was the test subject... Good and bad. The stage 2 is about the highest I would go unless you are drag racing only. Stage 3 is just far to much for a street car. I could only build about 40-65psi of compression with the old design stage 3. Even with the new stage 2, my compresion is maybe 110. The new one is much better, but stage 2 is the ticket.
SOHC S-14...
SleepyS-14
Postby KA24ETZTM » Sun Nov 08, 2009 10:28 am
SleepyS14, do you think I'll have a problem with my cam? My car will still be on the street ocassionally but she mostly gonna see the strip. I have the old stage 2 mech lifters when it was 290 duration 490 lift. Youve seen my setup, what you think since youve had a little more experience with the cam?
KA24ETZTM
Postby SleepyS-14 » Sun Nov 08, 2009 5:32 pm
If it is the old stage 2 then it will be fine, just the old stage 3 is a little big to even start the car. Stage 2 cam sucks enough to start the car. Takes about 5-8 times around and 1/4-1/2 throttle to get enough bang to start it. But once its up and running it idles very good (lumpy but good).
BTW. Don't ever check your compression with a stage 2 or 3. Not good, but it doesn't matter cause it rips.
SOHC S-14...
SleepyS-14
Postby KA24ETZTM » Sun Nov 08, 2009 6:07 pm
Cool deal, Thanks for your input :)
KA24ETZTM
Postby Jackasknissan » Sun Nov 08, 2009 6:18 pm
good to know, stage 2's it is thanks man
Jackasknissan
Postby sommmatt » Tue Nov 10, 2009 5:40 pm
Sleepy,
Thanks for the numbers! You're definitely affecting my cam choice.
What kind of vacuum are you seeing at idle? What kind did you see with the stage 3? Guessing 12in/hg?
Could probably get it to start on the mega squirt with little issue.
sommmatt
Postby SleepyS-14 » Tue Nov 10, 2009 5:46 pm
I don't know, maybe 10in/hg. I really don't know I havent had the car running in about a month. I have a new design stage 3 for sale also if your interested.
SOHC S-14...
SleepyS-14
Postby sommmatt » Tue Nov 10, 2009 5:50 pm
pm me price
sommmatt
Postby SleepyS-14 » Tue Nov 10, 2009 5:56 pm
Pm'ed ya
SOHC S-14...
SleepyS-14
Postby undesiredshoe » Tue Nov 10, 2009 6:00 pm
My O&J stage 2 is going in at the moment, Ill have a video up in a few days.
ImageStock block ka24e - 12.81 @ 113mph
undesiredshoe
Postby SleepyS-14 » Tue Nov 10, 2009 6:03 pm
I had to take about 10% fuel out everywhere. Makes more power with way less fuel. Tell me if it runs pig ruch with this new cam, I went from 11.7afr to way below 10afr.
SOHC S-14...
SleepyS-14
Postby tek_88 » Tue Nov 10, 2009 10:35 pm
undesiredshoe, let us know how your stage 2 goes..I might be getting that in a couple of weeks, not the mech one though.
tek_88
Postby SleepyS-14 » Wed Nov 11, 2009 5:50 am
I wouldn't even bother getting a aftermarket cam with out solid lifter and stiffer springs. I don't really think it will do much for you. The SOHC needs all the help it can get with head flow. Save your money.
SOHC S-14...
SleepyS-14
Postby torch'd » Wed Nov 11, 2009 3:22 pm
well i found my slow oil consumption issue... ithe the valve stem seels... they are leaking pretty bad. time to take the head off and rip it apart. can't wait to ge tthe cam and have the lopey idle.
sleepys-14: do u have any porting fdone to your head??? im not looking for a ton of poer, more so a fat curve around the 300 rwhp mark (yes im building the internals) was wondering if u had ported at all.
other than that anyone got a sound clip??
going fast, i can do that... this going sideways thing is tricky.....
torch'd
Postby Jackasknissan » Sun Nov 29, 2009 6:19 pm
underisredshoe, any updates yet?
Jackasknissan
Postby undesiredshoe » Wed Dec 02, 2009 1:43 pm
Got the cam in today. It started right up on the first try and everything but after the car was warm, it idled like stock with stock vacuum. I dont believe the stage 2 mechanical cam should idle this well. Im starting to think i was sent the wrong cam.
Heres a video
http://www.youtube.com/watch?v=zurbL0zEC2w
undesiredshoe
Postby Kfred » Wed Dec 02, 2009 1:54 pm
undesiredshoe wrote:Got the cam in today. It started right up on the first try and everything but after the car was warm, it idled like stock with stock vacuum. I dont believe the stage 2 mechanical cam should idle this well. Im starting to think i was sent the wrong cam.
Heres a video
You testdrove it yet? I think you are really going to like the change in power delivery. Keep us posted.
You can have alot of duration and still have a very good idle as long is there is no/little valve overlap. I said the same thing when I installed my jwt 272s. It idles with 17" hg vacuum very smoothly.
Then I went for a testdrive and I was smiling as I approached 7500rpms and it was still pulling hard.
I agree with Sleepy-s14, cams are a must in a sohc looking to make decent power.
RIP Nate(480sx)...
Kfred
Postby SleepyS-14 » Wed Dec 02, 2009 2:39 pm
My cam doesn't idle rough at all either. The only reason mine idles rough is could I have no idle control, so cracked TB and lean A/F=rough idle.
SOHC S-14...
SleepyS-14
Postby undesiredshoe » Wed Dec 02, 2009 3:41 pm
SleepyS-14 wrote:My cam doesn't idle rough at all either. The only reason mine idles rough is could I have no idle control, so cracked TB and lean A/F=rough idle.
Whats your vacuum at?
undesiredshoe
Postby SleepyS-14 » Wed Dec 02, 2009 4:42 pm
My vacuum is not going to be that you can consider because of the way I am running my setup. But, it is at about 15-16in. My car idles at 1000-1100rpms, lean, and more air, so what ever. You should bump your idle up a bit, to about 800-900rpms and lean it out to about 15-16A/F. Have you tried tuning for boost yet...
SOHC S-14...
SleepyS-14
Postby Jordan Gladman » Wed Dec 02, 2009 8:42 pm
Jack you should call up Colt Cams here in town and ask them about a cam. They did the cam for my last setup, they can pretty much do a grind to suit your build. It makes a HUGE difference. Im thinking about adding a cam grind to my setup pretty soon.
SleepyS-14 wrote:I wouldn't even bother getting a aftermarket cam with out solid lifter and stiffer springs. I don't really think it will do much for you. The SOHC needs all the help it can get with head flow. Save your money.
Whats your rationing for this? A higher lobe is going to increase valve lift no matter what way you toss it. Springs/solid lifters are going to contribute to higher RPM capability but I've had great experience with cams and the factory valve train.
Im not knocking the solid valve train, its is definately better than the OEM setup but I think a cam will still compliment the OEM valve train conciderably.
Jordan Gladman
Next
Return to SOHC KA-T
Users browsing this forum: No registered users and 56 guests
