sent the wrong turbo...
i order a 57 trim 48 a/r but they gave sent me a 57 trim 60 a/r... whats the diffrence.. can anyone tell me.. it it better or should i send it back
- tom550
its a bigger turbo. thats how i see it.
the a/r is meashured fron the center, well just read this
http://www.moddedmustangs.com/forums/po ... -trim.html
you cant really say a turbo is better than another.
it depends on the application, power goals, many things effect the best turbo for you.
dude its fine,not much difference ull just beable o utilize more boost.
atp's bad for sending te wrong sh*t.otherwise they are a reputable company.
currently n/a.
currently n/a.
- ppctx
yep'rs, else he would have posted a pic of the turbine cover markings. the part number tag should tell the tale. $5, he got what he ordered.Liger wrote:Pretty sure he is confusing the compressor A/R with the turbine A/R.
When websites sell a turbo based on the A/R, it is almost always based off of the turbine A/R. This is because the compressor A/R does not affect the turbo's performance like the tubrine A/R.
this is what he got,idk what a/r exhaust housing because u choose that when u order it.along with what bolt pattern u want. 5 bolt,4 bolt,v band,6 bolt..........
http://www.atpturbo.com/mm5/merchant.mv ... y_Code=TBN
i think this is what he was looking for which is tooooo small for 300+whp.
currently n/a.
currently n/a.
k noob question... the turbo it self doesnt match up right... like the oil return is not perallel to the turbo mounting side to the manifold.. also where the tubo comes out to the intercooler doesnt match up it upside down... is there a way to spin the turbo to match up..... I know Noob question but its a question...
its called clocking the turbo bro........loosen bolts on appropriate side and clock it,,,then tighten them back down . be care ful though so u dont damage the turbines.
currently n/a.
currently n/a.
