745hp/679tq @ 39psi
745hp/679tq @ 39psi
Postby redlineracer21 » Sun Mar 30, 2014 1:29 pm
Finally took my car to get dyno tuned. Very happy with the numbers, especially for a mustang dyno. All of the pulls were done in 3rd since 4th gear overloaded the dyno...
Heres a video my tuner put together for me.
http://youtu.be/DByltHOVt2w
redlineracer21
Re: 745hp/679tq @ 39psi
Postby cleantune » Sun Mar 30, 2014 3:38 pm
Nice numbers! What kind of fuel setup were you running with this?
Postby hotbox240 » Sun Mar 30, 2014 6:40 pm
Very legit! What clutch are you running?
hotbox240
Postby ka240de » Sun Mar 30, 2014 8:56 pm
Nice powerband edit thats alot of torque even for your numbers
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
ka240de
Postby RosadoRacing » Sun Mar 30, 2014 9:38 pm
Wow the s366 is making some serious power for 30psi. Can't wait to tune mine, im on the cast wheel but I'm also looking to boost 30psi. any pics?? Congrats btw
RosadoRacing
Postby RosadoRacing » Sun Mar 30, 2014 9:41 pm
I just noticed the dyno says 29.97. did you mistype or did u run 39psi if so 745 seems low compared to the 609 u made on 20psi.
RosadoRacing
Postby supakat » Mon Mar 31, 2014 8:36 am
That is a sleeper...
Postby redlineracer21 » Mon Mar 31, 2014 9:21 am
Fuel setup is dual walboros, -10 feed -6 return. Precision 95lb/hr primaries and 165lb/hr secondaries and e85.
Clutch is a 350z specialty z clutch. 5 puck with d21 flywheel.
The dyno only went up to 30psi but aem was showing 39ish.
The reason the numbers are low was because we had to do 3rd gear pulls instead of 4th. We tried one pull at first in 4th and overloaded the dyno by mph. We did a back to back pull in 3rd and lost around 30hp just from switching gears. This was also on a mustang dyno that reads low compared to dyno jet which is what the 609hp was tested on.
redlineracer21
Postby RosadoRacing » Mon Mar 31, 2014 10:45 am
So your easily making over 800whp. 39psi on a s366 is def 800+
RosadoRacing
Postby ka240de » Mon Mar 31, 2014 11:35 am
I request a spedo video of 3rd and 4th :) . Pleaase
also if you can get a 4th gear pull somewhere with a bit of tweaking , i think you would have the first 700wtq ka. Better beat kedbmx to it he should do the same with his new 10.5:1 setup.
ka240de
Postby redlineracer21 » Mon Mar 31, 2014 3:51 pm
Sorry i was wrong. This graph was a 4th gear pull and apparently he changed the mph limit for this one. The reason for low power is most likely due to the t3 backside is getting restricted. It really needs to be t4...
redlineracer21
Postby RosadoRacing » Mon Mar 31, 2014 4:10 pm
So your .70 t3?? Wow that's tiny. I have a t4 .88 but you have a great powerband n made enormous power for a .70
RosadoRacing
Postby NateDogg » Mon Mar 31, 2014 4:10 pm
That's awesome.
Looking at the chart it seems like the HP peak is a little low in the RPM range.
Do you think that's a result of the T3 exhaust housing?
What cams are you running?
'91 S13
Built, balanced KA-T
NateDogg
Postby RosadoRacing » Mon Mar 31, 2014 4:16 pm
The t3 def is restricting the power in the upper rpm range. It starts falling off at 6300 when it should keep climbing to 8k+. Still one of if not the best powerband I seen on the site. I shift at 7 n only made 630whp n ran 10.5 he should be deep in the 9s!!
RosadoRacing
Postby redlineracer21 » Mon Mar 31, 2014 4:29 pm
It peaks early due to the small housing. Builds boost quicker so hp comes on sooner. I run the bc 272s cams.
Thanks rosadoracing! My goal is to just see a 9.99 sec pass. If i can get further that would be awesome.
redlineracer21
Postby nelson240sx » Fri Oct 05, 2018 6:38 am
Nice numbers, looks like she'd be a blast to drive
KA24DE-T build 8/17 to current (EFR6758)
Burning corn since '09
http://www.e85forum.net
nelson240sx
Return to Dyno Results
Users browsing this forum: No registered users and 14 guests
