338HP/337TQ on E85 @ 15PSI
Postby Ada180sx » Mon Jul 23, 2018 9:20 am
Hi All,
I wanted to share my Dyno/Build with everyone. Namely because it was the kind of info I was looking for when doing my build but I was not able to find. Generally, the two groups on here seem to be the ones really pushing the power envelope for serious racing or the persons looking to “Turbo their KA” ie stock everything except a small bolt on t25 or ebay turbo and a box of Chinese parts.
Purpose: Bullet proof, reliable drift/track car
I wanted a car with lightning fast response, excellent throttle modulation that will be reliable for many years to come. I do not have the time or inclination to pull my motor yearly. Most of all, this car needs to be ready to party, whenever there is a party! I only do time attack to dial in susp settings. Primarily a drift car. Trailered to events. Occasional Sunday cruise to keep the fuel system clean.
Relevant Engine Mods:
Bottom End
Pistons: JE 9.0:1
Rods: Manley
Bearings: Clevite
All hardware is ARP
Standard bore, everything polished and balanced, decked for MLS head gasket (Cosworth) assembled by AES in Elk Grove
Top End
Cams: Tomei Poncam (270deg, 9.5mm lift)
Valve Train: Stock
Intake Mani: Stock (sealed for boost, swirl junk removed)
Mild Porting to gasket size
ARP Head Studs
Exhaust Setup
Ext Mani: Super Old School XS Engineering (might not flow the best but its very well made)
Turbo: Greddy TD-05H 18G with Kinugawa billet comp wheel (Amazing increase in response vs stock wheel)
Outlet: Tomei SR Outlet (Also super old school)
Downpipe: Trust Mild Steel (Predictably, old school)
Exhaust: Mandrel bent 80mm Stainless
Fuel System
Pump: Walbro 255
Reg: Aeromotive 13129
Inj: FC Engineering PL9 1200cc
ECU
MSPNP2 V1.3 (V 3.4.2 firmware)
Stock Dizzy/CAS and Coil
MAF Delete with GM Open Element IAT
DIY Autotune Trigger wheel
Boost control via DIY Autotune solenoid
Cooling
Rad: Mishimoto Dual pass
Oil Cooler: Earls 19 row with Trust block
I/C: R32 GT-R intercooler (Pulled from my GT-R when I upgraded to an ARC about a million years ago, in Japan) with custom piping
Intake: Custom job with Airaid Trackday filter
Final Gear: (Not sure if this is relevant or not) 4.6:1 from xterra front diff. At my home course (US AIR), this allows me to be solidly in 3rd instead of bouncing off the limiter in 2nd constantly…
Tuned by Mikey (@Mspec/Touge Factory)
Dyno results: (Two runs used for final tune)
Blue – Waste gate spring (0.8bar/12psi)
Red – Party Mode 1 bar/15psi
Dynamometer: Dynojet 224XLC (4wd capable)
The waviness of the “Party Mode” line was apparently related to waste gate flutter and conservative timing. Regardless, its not actually perceivable while driving.
I am certainly willing to share my tune (MSQ file) with any megasquirt fans that care to have a look.
Thanks for all the great info on this site.
-Ada180sx
Ada180sx
Re: 338HP/337TQ on E85 @ 15PSI
Postby Ada180sx » Mon Jul 23, 2018 9:22 am
This is a direct link to the picture:
https://i.imgur.com/5wSycp9.jpg
Ada180sx
Postby R34SR » Sun Dec 16, 2018 10:03 am
Nice respectable curve..cams doing a nice job.
MAXIMA COILS
ISIS RS3871R TURBO
Five-O 750cc injectors
ISIS V1 Manifold
ISIS FPR
PBM COBRA FLEX PIPE
XTD RB25DET 12b FLywheel
RB25DET SPEC STG2+ CLUTCH
Z32 Calipers
R34SR
Postby Cerevo » Sat Mar 02, 2019 12:07 am
Considered going to the excessive intake manifold?
Cerevo
Return to Dyno Results
Users browsing this forum: No registered users and 15 guests
