Advice Needed: Arp 12mm headstuds
Postby 240sx-venezuela » Wed Aug 15, 2018 1:03 pm
Hi everybody, I need some help here, I have bought a set of Rb26 arp 12mm headstuds for my ka, tapping the block to accept the new studs is an easy job, the hard part is the cylinder head wich need a little more machining for the nuts, and if you guys have some direct experience with these headstuds could you share what do you did to the head to accept the arp nuts? The new washers fits but the nut is a different tale.
240sx-venezuela
Re: Advice Needed: Arp 12mm headstuds
Postby s14fiend » Wed Aug 15, 2018 3:14 pm
I'm in a similar position I want to add larger headstuds since the majority of people in the 4 cylinder turbo community build to accept 12mm or even 1/2" headstuds but no one has specifics on the cost of machining etc. Last average machine shop I talked to locally said $300 bucks just for the machining bringing bare engine and head. Most of the machine shops have closed down in my area since its a big city and most people lease their vehicles so it's rare to find a good machine shop and when you do they are backed up for months..... so I got that dilemma where it's like keep building KA24de? When I can buy a complete 5.3 vortec LS engine for the price of headstuds and machine work.... The upside to going bigger studs and building the KA24de is that it's still decent street beast power when tuned right for the 240sx chassis and usually a LS vortec messes up the car unless it's just a drift missile where all you care about is short wheel base and ripping tires. With turbo ka24de torque kicks in slower making traction management just a bit more feasible which is one of the many reasons I decided to stay KA.
s14fiend
Postby 240sx-venezuela » Thu Aug 16, 2018 5:23 am
I usually like the idea of staying with the ka becasuse I usually dont like cross branding, every engine has its potential but its something much people do, I think the machining on ka worth the money, at least for me, it will hold a lot of boost, and your right, a LS weights a lot more, Im currently doind the machining today, to find what can I do with the Nuts as this is the difficult part
240sx-venezuela
Postby Toxic240 » Tue Aug 28, 2018 6:36 pm
My engine machinist and builder turned down the diameter of the nuts to fit and also turned down a socket to fit between the lifters. I am using the RB26 12mm ARP2000 head stud kit on mine for reference.
S14 - S366SXE / Bosch 210lb Inj / AEM EMS - WIP
Toxic240
Postby Keepinitpignose » Mon Oct 08, 2018 3:18 pm
I went to a well known /reputable machine shop in my area. They clearenced out between cam buckets some, also took a skim off the 12pt fasteners. ..and told me I could run pretty much as much boost as I would want having 'those headstuds' when I picked it up lol, then asked if it was a common thing for us to do.
Keep at it, I'm stoked to see another up and coming built KA
Keepinitpignose
Return to KA-T Tech. Advanced
Users browsing this forum: Bing [Bot] and 58 guests
