MaxRPM
Posts: 726 Joined: Sat May 21, 2005 10:20 pm
Post
by MaxRPM » Mon Jan 30, 2006 9:41 pm
I've did the search and came up with almost 2000 result. I'm just wondering, What timing kit do you use? Nissan? or is it okay to grab some off ebay? (i think they care cheaper than nissan) I konw i should go cheap on this, but want to see your guys opinion first. Thanks
Marcus
Wearer of Missing G-Strings!
Posts: 3342 Joined: Tue Sep 28, 2004 5:33 pm
Post
by Marcus » Mon Jan 30, 2006 9:44 pm
SleepyS-14
Posts: 1176 Joined: Thu Apr 07, 2005 4:23 pm
Post
by SleepyS-14 » Mon Jan 30, 2006 10:08 pm
All of the aftermarket stuff is good except:
-Chain guides, slack and tension side
-Tensioners( DOHC or SOHC)
The seals and sprockets and chains are good, but if you are not buying it piece by piece, go to nissan.[/u]
SOHC S-14...
dsylvia
Posts: 362 Joined: Tue Sep 07, 2004 7:02 am
Post
by dsylvia » Tue Jan 31, 2006 2:45 pm
i say only use OEM. i'd just get it from your local dealer. its more money that way, but at least you know its legit.
MaxRPM
Post
by MaxRPM » Tue Jan 31, 2006 4:14 pm
dsylvia wrote: i say only use OEM. i'd just get it from your local dealer. its more money that way, but at least you know its legit.
Cause the stealer....er dealer are almost double the price, but i guess it the best choice to go for
Marcus
Post
by Marcus » Tue Jan 31, 2006 4:46 pm
MaxRPM wrote: dsylvia wrote: i say only use OEM. i'd just get it from your local dealer. its more money that way, but at least you know its legit.
Online dealers knock off a ****.
www.nissanparts.org
Wykid240
Posts: 86 Joined: Wed Jan 11, 2006 6:35 pm
Post
by Wykid240 » Thu Feb 02, 2006 9:17 pm
How do you know that you need a new chain and or tenssioners and guides?
-Jeramy
Form Follows Function
