Part I think came from in between lower front cover and block, but I"m not 100% sure.
Can't find it on any part diagram, it's hollow on the bottom but has no holes.
Exhaust stud next to it fro scale.
What is this part?
Re: What is this part?
Thanks so much! You rock!
Took two engines apart a few weeks apart from each other, found one of the floor both times. Since I just pull the chain off it makes sense it would spring/fall out.. I have a new timing chain kit too. I thought it might be a dowel or go between the bottom timing cover and block.
