Ka24de alternator charge light help
npa4863
Post by npa4863 »
On the s14 ka24de (obd2) the charge light needs to be hooked up for the alternator to produce the correct voltage. After some research i found that theres a resistor in the cluster parallel with the charge light. Can some one ohm the charge lamp circuit in the cluster? Or if you know the correct resistor to delete the light?
[img width=768 height=1024]http://i949.photobucket.com/albums/ad336/npa4863/Mobile%20Uploads/20170214_131424.jpg[/img]
R34SR
Re: Ka24de alternator charge light help
Post by R34SR »
Years later, I'm in this same boat and I need the answer to this...
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
Mazworx z32 tranny swap
modulation
Post by modulation »
modulation
I'd try like a 470ohm 1/2 watt resistor. Measure the voltage while charging and go with more ohms if voltage is too high.
modulation
R34SR
Post by R34SR »
Appreciates, saw the 510 one and figured that's where I'll start.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
Post by p00t »
I had no idea about the resistor in parallel with the bulb. Interesting.
But the alternator finds it's voltage on the sense line that is connected to the battery. The alternator should just be using the bulb for diagnostics. It is possible the resistor plays a part in whether the bulb accurately lights (to prevent a false indication of a problem).
Is your alternator voltage wacky or okay? Have you tried a different alternator?
Post by p00t »
So the plot thickens sort of...
I checked out an s13 due to curiosity...
The same thing is happening except instead of a resistor in the cluster it uses the bulb check relay coil. Hmm.
So the current through the bulb/resistor is just enough to turn the circuits on inside the alternator.
100 ohm resistor sounds rights that is close to a relay... or use a relay!?
R34SR
Post by R34SR »
Well I wired it up with the charge light to ignition power, and the other line Direct to the alternator + stud...so far all seems well.inram completely new lines since I have aftermarket gauge cluster. Appreciate the insight though, and if it fails again I'll try the resistor.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
R34SR
Post by R34SR »
Thought I'd share, the alternator and voltage seemed fine for all of 45 MI s of driving then the voltages started to read high 14.9 to 15v....then it just stopped charging all together, ilet the car cool for 30 mins... And everything went back to normal... Seems like once the car heats up the voyage regulator is not happy about something... Perhaps that resistor is needed after all... I'll. Get one and report back.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
tuzzio
Post by tuzzio »
I've never really understood this. I havent had a stock cluster / resistor in 5 years, and no issue.
I'm unsure if its cause I have a quest alternator, or a standalone, or an aftermarket cluster.
But my car is 14.2-14.4 always, and drops accordingly when the fans come on, or the blower motor. Same thing as my buddies 2J car.
R34SR
Post by R34SR »
Glad to finally put this topic to sleep.
470 ohm resistor so far has cured my issue since i replaced my factory cluster with a custom one.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
R34SR
Post by R34SR »
So even though this worked, seems like i damaged the regulator from running without the resistor for too long....thats my current assumption...i cant believe how simple yet frustrating this charging system has been.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
