Importdudes' Build thread
So I blew the rebuilt stock internal ka24de a few weeks ago. So i finally STarted my Rebuild process. I will Update as i go along with the build. Thanks for Viewing. I will Also be Doing it all myself besides the Bore/Hone
Took the Motor Out 9/28/08
9/29/08 I removed the Intake/Exhuast manifold and removed the Head.
Build will Be
Supertech 9.1 89.50mm
Eagle rods
New STock Head Bolts
Felpro PT HG
Build will Be
Eagle rods
Felpro PT HG
- myowncasualty
all that work and no ARP head studs? why not, its $100 more to your already somewhat expensive rebuild?
10/9/08
Droped off block to get hot tanked/overbored/hone
*FOUND OUT WHY I HAD clutch DISENGAGEMENT ISSUES AND MAJOR VIBRATION
PILOT BUSHING WAS BROKEN+NOT Pushed in FAR ENOUGHT
BAD Bushing
GOOD BUSHING
BAD Bushing
GOOD BUSHING
11/06/08
Pistons In Tqd Down
Cleaned Head
Clean oil pan/Valve Cover
http://www.youtube.com/watch?v=o7IVyTXj9e0
plans for tomarro is
Install Head/tq down/cams/Timing Chains
Pistons In Tqd Down
Cleaned Head
your going to run a topline rebuild kit? if you are take the timeing guides and throw them in the garbage and get a set of steel backed plastic guides. i only changed my lose tensioner about 30K ago and now i have about 3/4 of a tight guide left. i have about $400 into the rebuild so im just going to let the thing gernade its self.
KA24ET RB20 turbo, 460cc
yikes naw, im using OEM guidesdopeassjackson wrote:your going to run a topline rebuild kit? if you are take the timeing guides and throw them in the garbage and get a set of steel backed plastic guides. i only changed my lose tensioner about 30K ago and now i have about 3/4 of a tight guide left. i have about $400 into the rebuild so im just going to let the thing gernade its self.
thoese are Brand new Head Bolts
11/10/08
Installed Head
Installed Cams/caps/
Installed Timing Chain/Upper Cam Chains
WAITING ON OIL PUMP REGULATOR/rebuild ****
"RANT" dam guy i order parts from said "i thought u wanted the prices only, not order it"
that was Monday of Last Week! Now i have to wait another 3-4 days!!!@#!
On to pics
PARTS PILE GETTING SMALLER AND SMALLER
Installed Head
On to pics
11/12/08
Painted timing covers, Thermostat housing, pvc box,
Installed Timing Covers/Thermostat housing/thermostat/oil filter adapter
rebuilt the oilpump old gears new regulator/spring/washer/oil pump cover
11/14/08
Nouched the head, b/c it was hiting my DP
Cleaned Wg Tube from rtv
Then THIS MOFO Was trying to bite me for 5 mins, i put everything down and killed this sucker
If my friend is free this sunday the motor might go in
I still need to pickup a few bolts/ 5/8 heaterhose for rear fitting to heatercore
also need to rtv the oil pan(its temp bolted to strigten the flange)
basically longblock is done
11/14/08
11/18/08
had return bung welded just incase
Rtv the oil pan
Installed turbo manifold
installed distrubator
orderd dw 550cc injectors
Degrease engine bay
Roll Engine Hoist from backyard into garage and strap it on to install trans/clutch/fly
This Saterday Mourning the engine is going in the car
Rtv the oil pan
Degrease engine bay
11/21/08
Friday Night Fiddled with the Trans/TOB/Shifter (EBAY CRAP) had to redrill a hole and jb weld one closed
11/22/08
Put engine.trans in started about 3-4pm
Tucked wiring harness/taped alot of it
Pluged in sensors/tranny harness ect
WHATS LEFT TO DO NOW.
Install DP
Install O2 sensors/wideband on DP
Refill trans mt-90(waiting for monday no stock)
Install Shifter
Install Maf pipe
Install Testpipe/cat
Then im ready to fire her UP
Probly Tuesday mourning ill try to do that
woo woo SO CLOSE
11/22/08
Install DP
Install Shifter
Install Maf pipe
woo woo SO CLOSE
11/24/08
installed shifter/put in mt-90
installed tranny harness
11/25/25
install maf,cold pipe,downpipe and everything esle
I FIRED HER UP 40mins AGO
STARTED ON FIRST TRY
ROCK SOLID IDLE EVERYTHING GOOD EXCEPT OIL PRESSURE
SHOWED ~35PSI COLD ON MY mech guage
i had this same oil pressure on my old motor!#!@#!
i replaced the regulator and Cover
either my guage/T's for oil supply is cloged or i need a new oil pump still:((
THE IS THE FIRST MOTOR I BUILT myself and im more than happy with what i did
it feels SOOO GOOODDDD
Now i just gotta fix the oil pressure problem(***** bi*ch to do in car
11/25/25
forgot to update
but turns out for some reason when i connect gauge to turbo T it shows 35psi max
but if i Measure gauge directly from the T on the block i get normal(75psi cold)
so everything has been running great
Turbo failed 1-2 weeks after the build so it has been down
i just got the car up a few weeks ago with a new turbo
Everything is running smooth
NO oil Leaks, NO Leaks for that matter
Solid 22VAC
Trans Leaking little from the Ebay Short **** with no Boot on
Next thing i need to fix is the Megan Type 2 exhuast rubbing on frame(annoying)
Thanks for everyone that helped me on this thread or gave comments
http://www.youtube.com/watch?v=_SfGfmRAEqo
here is a video for now until i can get to the track or make some videos
Solid 22VAC
UPDATE
10psi on a 57 turbo held fine
@ 13-14psi
Head lifted!
Freakign topline headbolts!
Well i just finsihed installing ARP HEADSTUDS, and another felpro PT
Just wanted to update you guys
Currently will be removing cams (heatcycled) and will be retqing studs to 65lbs
Then I believe my nismo thermostat is stuck. So i gotta get a new oem thermostat
DO IT RIGHT THE FIRST TIME! SPEICALLY ARP HEADSTUDS!
@ 13-14psi
Head lifted!
