Hi everyone,
So, I'm looking for a chain kit + front cover/oil pump. I was going to go all Nissan since I'm a Nissan purist, but I do not want to dish out $600+ since this motor is real old and might need a rebuild in next 3-4 years. Also, it was brought to my attention that some of Nissans parts are rebranded parts.
S14 ka24de chain kit + front cover/oil pump recommendation
Re: S14 ka24de chain kit + front cover/oil pump recommendati
Unfortunately, if you want reliability out of your car/engine, you have to shell out some money for oem parts.
That's my opinion any way.
<< Yuh dun know!!
I'm in the process of an engine rebuild in the daily and unfortunately for my bank account I went with OEM parts as well.
I also went with all ARP hardware so I don't have to do worry about anything if I wake up one day and bolt turbo bits to it like it's a great idea.
How much did you end up spending if you don't mind me asking?Bubba wrote:I'm in the process of an engine rebuild in the daily and unfortunately for my bank account I went with OEM parts as well.
edit: I'm hearing Oem Nissan is OSK? can anyone confirm?
I didn't total anything up because of how many things I've got going on at once but I know after the timing parts, ARP studs, clutch/fw, and fluids I'm up near or over the $1k mark.
I've got a 5 speed swap, engine rebuild, and suspension overhaul going on all at the same time.
did you do the oil pump as well?Bubba wrote:I didn't total anything up because of how many things I've got going on at once but I know after the timing parts, ARP studs, clutch/fw, and fluids I'm up near or over the $1k mark.
Would it better to just buy a whole new Complete Cover Timing Chain Assembly....
Or just replace the Oil Pump Gear + Oil Pump Valve Relief Assembly, and it'll be good as new?
