kelford intake/ex cam help!!
Imation1305
Post by Imation1305 »
Good day,
I have a set of kelford 260 degree cams shafts and I am trying to identify which is the intake and which is the exhaust.
One has L86-EX 2 holes.
One has L-50 with 1 hole
I assumed the EX cam was exhaust but currently the person I bought the motor from has the L86-EX camshaft on the intake side?
Any insight would be a great help
NukeKS14
Re: kelford intake/ex cam help!!
Post by NukeKS14 »
the intake cam will have the dowel straight inline with the first lobe. On the exhaust, if the dowel is at 12'o clock the first lobe will be at 2'o clock ish
https://forums.nicoclub.com/how-to-iden ... 54484.html
So it SEEMS like the orange is intake and green is exhaust on the kelfords, according to that info...
Alternately, you could always contact kelford...
https://www.kelfordcams.com/global/contacts
Post by street_240sx »
NukeKS14 wrote: Wed Dec 30, 2020 6:18 pm the intake cam will have the dowel straight inline with the first lobe. On the exhaust, if the dowel is at 12'o clock the first lobe will be at 2'o clock ish
He has aftermarket kelford cams. Don't think oem identify is the same with most aftermarket ones
NukeKS14
Post by NukeKS14 »
:| My Brian crower cams were blue - exhaust yellow - intake.
Either way, the mfr should be able to answer for sure. Should be pretty easy to call/email them.
