I currently have the setup below:
Doc Race turbo mani
Turbonetics T04E
Stock cylinder head mild port job
236/242 OEM cams
Eagle H Beams
Wiseco pistons (9:1)
ARP head studs
Felpro HG
ID1000 injectors
Nistune ECU
I have checked the block and head for warpage and get nothing. Well, a .001" feeler gauge will not fit under my straight edge. I take my car to the dyno and is laying down 431 HP and 442 TQ. Everything looks good on the dyno and it is a clean run. But I have been noticing that I am getting combustion pressure leakage into my cooling system (verified with a block test) This is the 3rd set of ARP studs and HG I have changed for this issue. I was wondering if I would have better luck with a Cosworth HG? I have tried Cometics before and blew it at 10 psi boost. But is the Cosworth really that much better??? Also I tried the search button but there is really nothing on surface prep for this gasket.
Thanks in advance,
Cory
Cosworth head gasket. Better?
- nissanfanatic
Re: Cosworth head gasket. Better?
What are you torquing the head studs to? I never torque past factory spec on the 10mm studs.
Seems extremely odd that you blew a Cometic at 10psi...(?) I never had a problem on Cometic+ARP up to 32psi on a T04R.
I have had better result with Cosworth over Cometic but I also had advanced boost timing with Cometic that lifted the head and separated fire ring. What degree are you at with 10psi? 93 or E85?
Torqued headstuds to instructed 70 ft/lbs with Snap On electronic torque wrench.nissanfanatic wrote:What are you torquing the head studs to? I never torque past factory spec on the 10mm studs.
15* ish on the last load cells on the max rpm (6800 rpm) and running 19% alchohol, 65% 92 pump, 16% toluene IDK gasohol blend that we are experimenting with. No knocking or detonation via plug chop. Also no damage to anything else verified with a bore scope. EGT stable around 1300 deg on the top end. Although the first time around I stretched the heads studs and had to replace everything. Could it be too aggressive of a timing on the bottom end? I do peak 442 ft lbs @ 4500 rpm.supakat wrote:I have had better result with Cosworth over Cometic but I also had advanced boost timing with Cometic that lifted the head and separated fire ring. What degree are you at with 10psi? 93 or E85?
- nissanfanatic
I did too originally and they stretched. Now I only torque to 60lbs ft. YMMV.
Cool. Another Cory. LOL Hmm sounds like a good theory.nissanfanatic wrote:I did too originally and they stretched. Now I only torque to 60lbs ft. YMMV.
yeah i once torqued my arp 10mm to 73 ft-lbs but it wasn't started. hopefully i didnt wreck them. i see id probably only torque them to 60 ft-lbs for an n/a build and maybe 65 or so if i boosted. but i do plan on going bigger studs one day.
no one has mentioned ;
kedbmx's 12mm arp2000's held 10:1 compression , 42 lbs of boost, 8000+ rpm, and 225 horsepower per cylinder !
cosworth gasket correct me if i'm wrong
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
